| Home > General Chat > 12g295 valve seat inserts. | |||||||
44 Posts Member #: 8820 Member alrewas, staffordshire uk de13 7bs |
15th Oct, 2010 at 04:23:55pm
hi,
15th Oct, 2010 at 04:31:08pm
15th Oct, 2010 at 04:48:26pm
do you know where i could get the inlets from? |
15th Oct, 2010 at 04:49:34pm
you only need to insert the exhaust seats, and this need to be professionally done on a serdi machine
15th Oct, 2010 at 04:49:45pm
It is not normal practise to fit them on the inlets, but if you insist:
15th Oct, 2010 at 04:52:59pm
i had a go and porting and polishing and got the seats quite a bit so i would prefer to replace them.
15th Oct, 2010 at 04:55:48pm
On 15th Oct, 2010 d1k1m4y said:
paul what size am i looking for on this list? You will have to work it out. At least 1mm bigger than the OD of the valve, in my opinion. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
15th Oct, 2010 at 05:03:45pm
going for 33mm inlet valves so looking for a seat with an OD of 1.33+" ?
15th Oct, 2010 at 05:11:12pm
going for 33mm inlet valves so looking for a seat with an OD of 1.33+" ? or: Valve Seat Insert - 1.12" ID, 1.37" OD, .219" H does that sound right or am i being a retard. thanks alot rich Sounds right if 1.37" is the next biggest size up. (33mm+1mm)/25.4 = 1.34" Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
15th Oct, 2010 at 05:25:15pm
so how do i order them off this website or who in the uk would make some?
