| Home > Help Needed / General Tech Chat > Running Lean with Rich needle, air leaks? | |||||||
![]() 568 Posts Member #: 1200 Post Whore Bristol |
16th Oct, 2010 at 07:02:57pm
Hey all, im trying to get robs british open running right, initially it was down on power and running really rich and coking up the plugs, i had the head skimmed and new head gasket fitted as it was down on compression on all bores,
19th Oct, 2010 at 12:36:28pm
Dash pot oil? Own the day
19th Oct, 2010 at 01:22:23pm
nope, but that was the problem on my mates mini on the weekend, done a compression test last night and its gone between 2 and 3 on the gasket again :( gonna have to get the mx5 out and motd this week to have a car otr |
19th Oct, 2010 at 06:05:47pm
Are you sure it's the gasket gone? All the valves are good and sealing? Chuck some oil down the bore turn it over and do the comp test again On 7th Nov, 2011 apbellamy said:
19th Oct, 2010 at 09:32:56pm
Is the block cracked / erroded between 2 & 3? In the 13's at last!.. Just |
19th Oct, 2010 at 10:00:55pm
the cause will be pre ignition DETONATION what keeps taking the head gasket out here
