| Home > Help Needed / General Tech Chat > running veg oil astra dti | |||||||
44 Posts Member #: 5252 Member essex |
16th Oct, 2010 at 10:56:45pm
hi i no its not mini related but im sure someone on here nos a bit
547 Posts Member #: 2928 Post Whore peterborough |
16th Oct, 2010 at 11:31:28pm
not sure what engine you have un the dti,
Jack Jones |
17th Oct, 2010 at 10:09:26am
Some have run a little in-line pre-heater to thin the oil down. Just make sure you change the filter regular. On 19th Jan, 2010 wil_h said:
17th Oct, 2010 at 10:11:20am
As it soon gets clogged up with bits of old chip!
On 17th Oct, 2010 Jason G said:
Some have run a little in-line pre-heater to thin the oil down. Just make sure you change the filter regular. On 28th Aug, 2011 Kean said:
17th Oct, 2010 at 10:14:40am
Veggy oil from cash'n'carry and super markets is just as expensive as diesel nowadays anyway.
17th Oct, 2010 at 02:13:54pm
http://cgi.ebay.co.uk/used-waste-vegetable...=item2a0afd8fcb On 26th Oct, 2004 TurboDave16v said:
17th Oct, 2010 at 02:34:55pm
The cheapest solution is domestic heating oil - it's virtually identical to pump diesel, just needs about 2% 20/50 multigrade added as a lubricant for the injection pump and injectors. Less than 40p a litre if you fill your heating oil tank at the right time of year.
17th Oct, 2010 at 02:44:25pm
Cooking oil is not illegal. Regulations regading duty on vegetable oil as a fuel has changed in the last few years, and as such, as long as the volume of oil used falls bellow the maximum volume before you have to pay duty, it is duty free. That volume is a rather significant amount and the average person will not reach it unless they are a commecrcial business for example. I cannot remember what the max volume before duty is, its been about 2 years since I looked into it. On 26th Oct, 2004 TurboDave16v said:
17th Oct, 2010 at 02:47:48pm
http://www.smartveg.com/faqs/fuel-duty-vegetable-oil.php On 26th Oct, 2004 TurboDave16v said:
![]() 509 Posts Member #: 1027 Post Whore Germini, black forrest |
17th Oct, 2010 at 03:08:51pm
That's the problem: old diesels are very futuristic in regards of environmental protection.
Edited by Asphalt on 17th Oct, 2010. [X] nail here for new monitor |
17th Oct, 2010 at 03:30:47pm
On 17th Oct, 2010 Sprocket said:
Cooking oil is not illegal. Regulations regading duty on vegetable oil as a fuel has changed in the last few years, and as such, as long as the volume of oil used falls bellow the maximum volume before you have to pay duty, it is duty free. That volume is a rather significant amount and the average person will not reach it unless they are a commecrcial business for example. I cannot remember what the max volume before duty is, its been about 2 years since I looked into it. I stand corrected Colin :) It is a while since I looked into it. It seems that allowance only applies to cooking oil though, the usual scam around here is heating oil (as red diesel is too easy for Customs and Excise to spot with a simple tank dip) and my heating oil invoice certainly still has the dire warning on it "Must not be used as a road fuel". But, as Jason says, why would anyone use cooking oil - it's virtually the same price as pump diesel - and I wouldn't put used stuff into an engine unless it had all the treatment and filtration for which the capital outlay is enourmous. Also, most modern diesels are electronic (common rail) injection and they are very sensitive to fuel quality. Schrödinger's cat - so which one am I ??? |
17th Oct, 2010 at 03:54:15pm
Heating oil mixed with diesel is problably the way forward.
17th Oct, 2010 at 04:38:32pm
Our machines use mineral oil, and one of the lads burns that in his Jeep, which if you ask me, defeats the original point of burning vegetable oil. That point being that vegetable oil is a renewable carbon fuel, as renewable as it can be under the current technologies, while mineral oil or fuel is a stored carbon fuel
![]() 1137 Posts Member #: 1450 Post Whore Near Paris - France |
17th Oct, 2010 at 06:35:31pm
We should all be environmentalist. Not the dreamer kind but still.
Rusty by nature
They said "That sounds rough mate." I said "Cheers it cost me a fortune to make it sound like that!" |
17th Oct, 2010 at 07:03:27pm
^Gah, my car runs without trees [X] nail here for new monitor |
17th Oct, 2010 at 07:09:45pm
That's where you are wrong my European friend On 26th Oct, 2004 TurboDave16v said:
17th Oct, 2010 at 07:31:38pm
a mate told me if you mix veg with a bit of white sprit it should be fine to use anyone else heard this |
17th Oct, 2010 at 07:53:55pm
yes.
). Idealy, even these get better injectors & different tune of the injection pump timing.
