| Home > Help Needed / General Tech Chat > Grey clutch cover | |||||||
![]() 558 Posts Member #: 8143 Post Whore London |
17th Oct, 2010 at 10:06:20am
17th Oct, 2010 at 10:09:42am
if its too high for you slacken off the little bolt under the arm a bit.
17th Oct, 2010 at 10:12:37am
When you press the pedal down, apart from the very first little bit, is it uniformly hard all the way down or does it only go hard at the bottom.
17th Oct, 2010 at 10:35:32am
It seems to go hard at the bottom, I'm thinking of changing it later on to a Orange as Grey seems too much, I'll try changing the arm and pins and see if it makes any difference, could it be the pushrod too? As I have a new one too? |
17th Oct, 2010 at 10:53:03am
It could just be adjustment as Joe says if it operates at the bottom only (I forgot....).
17th Oct, 2010 at 10:57:33am
Cheers guys, another thing, does it really need a grey cover? It is a NA 1380 which had a RR figure over 100bhp, but then again I have a friend running a 1380 on a normal blue cover and his is fine and has about 90-100bhp? |
17th Oct, 2010 at 12:04:59pm
I really think a grey is far too heavy for your power output.
In the 13's at last!.. Just |
![]() 100 Posts Member #: 4826 Advanced Member Isleworth |
17th Oct, 2010 at 01:06:40pm
I'd go for the orange, grey is for 130+. ive got a blue spare if you want it mate. |
17th Oct, 2010 at 06:55:02pm
Sorted gearchange now, clutch definitely needs sorting, I think I'll have to change to an orange diaphragm, change clutch arm and bits and give it a good bleed, reverse is crunchy and hard to get into |
