Home > Help Needed / General Tech Chat > Correct oil pressure (psi)???
turbo22
Member #: 3684
wisborough green west sussex
I have just wired in my new tim oil pressure gauge with sender and as soon as i start up the pressure goes straight upto 100+ psi. Is this the right sort of presure for a new build or have i wired he gauge wrong?
cheers chaps.
TurboTom
Member #: 7936
DK-8450 Hammel. Denmark
That is way to high. Half the presure could do it. It sounds like it is wired wrong. If not, check the presure relief valve.
If i have more toys than you when i die, I WIN
if its electronic sender sensor thing, check its referencing the correct voltage, mine are 5v or there abouts, if wired up wrong they can easily read double
