| Home > Help Needed / General Tech Chat > no reverse | |||||||
109 Posts Member #: 8630 Advanced Member |
18th Oct, 2010 at 10:45:14pm
got my 998 turbo up and running today and thought id give it a spin round the block to see how it went.....well it didn't.
19th Oct, 2010 at 07:55:26am
Sounds more like your gearbox is broken. On 11th Feb, 2015 robert said:
19th Oct, 2010 at 08:05:02am
Is the base plate of the gearchange remote housing on the correct way round? |
19th Oct, 2010 at 09:16:31am
I reckon the yoke inside the gear selector housing is upside down. This would explain the problem.
969 Posts Member #: 47 Post Whore Not very sunny swanage |
19th Oct, 2010 at 09:50:38am
i reckon tom is right.... at least thats what happened to me years ago...... And on the 7th day........... God created turbochargers! |
19th Oct, 2010 at 04:32:30pm
ok thanks i thought so
19th Oct, 2010 at 04:58:00pm
Take out the gearstick first from inside the car, if the yoke is "pointing" to the top its 180 deg out.
19th Oct, 2010 at 05:04:45pm
i dont fully under stand what you mean by the yorke is that the connection on the gearbox for the selector shaft attaches too |
19th Oct, 2010 at 05:05:44pm
The yoke is inside the gear change housing which is at the bottom of the gearstick. Take the gearstick out from inside the car and you will see how it works.
19th Oct, 2010 at 05:08:19pm
so tom what do you mean by pointing up ive got the smaller hole at the bottom and the bigger one at the top |
19th Oct, 2010 at 05:10:58pm
On 19th Oct, 2010 Tom Fenton said:
Take the gearstick out from inside the car and you will see how it works. This^ I can't remember the exact details of it off the top of my head.
19th Oct, 2010 at 05:14:49pm
ok i think im going to leave it for now cos i havnt got a clue how it should work |
19th Oct, 2010 at 05:22:06pm
Have you had the selector mechanism apart recently or disconnected from the box? If so then follow the advice above. If not, then you have a gear box fault.
19th Oct, 2010 at 05:31:05pm
ive stripped my donor manual and put all the manual parts in my automatic cos the shell was in a much better condition.
19th Oct, 2010 at 06:19:51pm
I take it from your comments, you've not had the gearbox apart? |
19th Oct, 2010 at 08:36:22pm
no the gearbox and engine have not been touched |
19th Oct, 2010 at 08:55:29pm
On 19th Oct, 2010 smudger483 said:
ok i think im going to leave it for now cos i havnt got a clue how it should work I agree. Why bother, and try learning something new.. On 13th Jul, 2012 Ben H said:
19th Oct, 2010 at 09:04:38pm
so can you put the gear stick in the wrong way |
19th Oct, 2010 at 09:17:45pm
19th Oct, 2010 at 09:31:37pm
yeh fine and it works now just ive got no reverse |
20th Oct, 2010 at 08:50:51am
did you have reverse before?? And on the 7th day........... God created turbochargers! |
20th Oct, 2010 at 09:06:26am
Does the gear stick actually move the extra travel to the right and backwards after you have lifted it to clear the blocking mechanism ???
20th Oct, 2010 at 12:57:00pm
yes reverse worked fine before and i can select all gears as normal.
20th Oct, 2010 at 04:51:29pm
ive just put my car on axle stands and started it up to see how the gears are working at the moment it goes throu 1-4 no problem they seem normal but when i put it in reverse it goes forward.
20th Oct, 2010 at 05:12:46pm
Which forward is it - you should be able to tell from the speed of the wheels - if it's 4th then the selector shaft isn't rotating enough to reach the reverse gate.
