Home > Help Needed / General Tech Chat > Metro turbo blow off valve
Bakerwoodlands
Member #: 8445
Does anyone know what pressure the standard blow off valve should operate at on a standard metro turbo? I have gradually incresased the boost via a bleed off valve on the waste gate pipe to around 8 psi (slthough the boost gauge works the ECU no longer seems to want to step the boost automatically at 4k so thought I would beed off to achive same instead) and it now sounds as it the valve is operating. When I change gear the boost increases to around 12 then drops so I thought it was 12 but given the noise it makes at full boost I'm not sure it's not operating before this.
Thanks
From what I recall it's about 10psi.
Bakerwoodlands
Member #: 8445
Thanks for the info. How do you get boost above this then -do I have to blank off and fit a different one of can I pack out the existing to riase its operating pressure?
Remove the hose to the ECU and fit a bleed valve. Make sure you get the car tuned afterwards or you risk melting something.
Yes you can just block it off, or pack it out.
