Home > Help Needed / General Tech Chat > bit of a confusion (supercharger inlet track)
blister
Member #: 2590
Croydon
been over on tmf not getting a quick ansewer from people that may of had this problem?
right i bought a second hand inlet manifold, it is a vmaxscart item i put it up against the face of the charger and made a gasket to see where the holes will have to be drilled
on complete of this gasket i have noticed that both faces of the supercharger protrude into the bore of the inlet,
my question is, are they all like this and will this not affect flow?
if there is enough ally there simply ease (grind / file / bite) off some it make it a smoother transition between the 2
as above,
Stuff a load of rag in there and hoover while filing, I'd just round it off and make the hole in the plate wider to make up for the lost area.
