Home > General Chat > Valve seat angle?
Nial
Member #: 9073
Edinburgh
In the video here...
http://www.youtube.com/watch?v=CUIcEdINWmo
...David Vizard points out that with a 45 degree valve seat when you lift a valve 50 thou then you only get 35 thou clearance between the valve and the seat.
With a 30 degree valve seat if you lift the valve 50 thou you get 43 thou clearance between the valve and seat, giving much better low lift flow.
This sounds a no-brainer, why are't more people using 30 degree seats?
Nial.
Because the valves don't centre and wear out.
Nial
Member #: 9073
Edinburgh
Fair enough for a road engine.
Do many people building race engines use 30 degree seats?
Nial.
Don't people use 3-angle valve seats?
Yes, but he's reffering to the actual valve seat being 30deg not the usual 45.
Oh, I see.
Mr Joshua
Member #: 1954
Luton Bedfordshire
Now go and get a price for these valves.
most inlet valves come cut with 45 degree seats which have to have extra material added to them (Stelite) then reground to the new 30 degree angle.
Any guesses on how much this process costs, hmm.
£80 per valve! On top of the cost of the valve. Thats why no one uses 30 degree seats.
Edited by Mr Joshua on 20th Oct, 2010.
Own the day
Nial
Member #: 9073
Edinburgh
If the back of the valve is cut at 45 degrees then you can get a 30 degree seat just by removing material.
The head might need work to achieve 30 degrees without sinking the valve, though if you were getting seats replaced this shouldn't add much.
Nial.
I agree with Nial. This should not be expensive if fitting new seats anyway or OS valves.
