Home > Help Needed / General Tech Chat > boost gauge reading minus and DV not making a sound
smudger483
Member #: 8630
ive noticed the boost gauge is reading minus 20 inHg on tick over and when im going throu the gears it peaks at 0 and then drops to 20 inHg till i build up the revs and my dump valve is making no noise its a Bailey DV 24. i can see the piston inside the DV open when i accelerate and close when i release the throttle. could this be my actuator because at the moment ive mounted it half open does it need to be fully closed to gain boost
pot_dan
Member #: 326
bradford, west yorks
Have you taken the feed from the one way valve for the servo? Or maybe part throttle lean off? I have done both before now. Lol
smudger483
Member #: 8630
my take off is from the servo hole to a t-piece to the DV and then off to my gauge ill get a pic
Is this on Axle stands? If so you will not be producing any load hence any boost. Also having the wastegate propped open by the actuator will cause it not to produce boost.
smudger483
Member #: 8630
yes its on axle stands and im going to sort the actuator out tomorrow so the wastegate is closed
smudger483
Member #: 8630
this is how ive set it up
All looks right, -ve reading at idle is correct.
I would say you aren't making boost, as you say that you have mounted the actuator half open your problem is obvious.
Even at full boost I bet the actuator/wastegate never reaches half open. In fact you actually need pre load to make boost. that is the actuator should be pulling the wastegate shut.
smudger483
Member #: 8630
cheers wil it was just for my piece of mind thanks guys
