Home > Introduce Yourself > HIF fuel mixture
tojar
Member #: 9140
I have A 1275 engine prepared by C-Tech with a Garrett turbo and HIF carb. I cannot seem to get the mixture right. I am using a BDD needle and the engine will bog then backfire then die. No problem restarting but cannot accelerate...same thing happens again. I have tried adjusting the mixture but I really don't know what I am doing. Can anyone assist me?
Sounds like the fuel pressure is not rising with boost.
Are you using the metro plenum, FPR and fuel pump?
Is it a metro turbo carb with the hole from the plenum face to the float bowl open?
Have you blocked the float chamber venting pipe ?
as above, .......................... but it sound too rich, have you tried to lean the carb off using the mixture screw?
Get it setup on the rollers. It's worth every penny.
tojar
Member #: 9140
I now have a BDL needle in and it starts immediately and revs up good except that it seems to be missing. It also blows smoke out the tailpipe. Any further suggestions?
