Home > Introduce Yourself > can you help with info for my turbo mini
ldst75
Member #: 4371
Hi eveyone, this is my second post since joining, i`ve been building my mini cooper for the last 5 years this coming january, its a tahti blue sports pack cooper, i`ve removed both sub frames and had them shot blasted and re sprayed, it has a turbo bulkhead installed it has poly bushes all round, new 4 pot metro front brakes, and i have a metro turbo engine about to go in*smiley* i`m looking for info on the install i have a mpi fuel tank? are the standard engine steadys ok to use?what heater should i use as my mpi heater will need moding? any info will be greatly received. any tunning info will be good to, what boost should be run, what ignition timing should the engine be set at? i will be hopefully post some pics soon.
regards Ldst75
