| Home > General Chat > Which is the best type of block? | |||||||
400 Posts Member #: 2563 Senior Member Tamworth |
22nd Oct, 2010 at 03:29:33pm
Hi all,
22nd Oct, 2010 at 03:34:22pm
Some say A some say A+
22nd Oct, 2010 at 03:53:20pm
i believe the A block were made of a higher grate material, and the A+ was designed to increase stiffness ( so a lower grade material can be used )
Yes i moved to the darkside |
22nd Oct, 2010 at 03:57:50pm
Anything that has five main bearings.... On 17th Nov, 2014 Tom Fenton said:
22nd Oct, 2010 at 04:28:04pm
I don't think there is a right or wrong answer to this. There are no horror stories of either A or A+ blocks wearing or breaking. It just seems preference based on rumour.
http://www.twin-turbo.co.uk
22nd Oct, 2010 at 04:53:24pm
Iirc the twini runs a gt block in the rear and an a-s in tge front please correct me if im wrong but they are highly modded Drives
22nd Oct, 2010 at 05:14:11pm
The only issue I'm aware of - from reading on here and in Vizard - is most of the pre-Aplus blocks have a void in the casting above the centre main bearing that makes them weaker at sustained high RPMs (Vizard talks about blending out all the casting marks in that area if you are going to use one). But as a turbo motor runs lower RPM it shouldn't be an issue.
22nd Oct, 2010 at 07:04:50pm
Not all have that Roderick.
![]() 6965 Posts Member #: 507 Fastest A Series Mini in the World leeds/wakefield. |
22nd Oct, 2010 at 08:37:03pm
i have some A series blocks with and without the void above the centre main, |
22nd Oct, 2010 at 10:49:24pm
The a+ block in my opinion, is highly unlikely to be a lesser grade. The strengthening ribs are only there to retain rigidity after they removed so much metal. The casting uses less naterial, meaning its cheaper to make, meaning they can make more of them for the same price. The A+ block is lighter by my reckoning.
22nd Oct, 2010 at 11:06:24pm
a bare A+ block is a weeny bit over 35kg (like 80 grams) On 28th Aug, 2011 Kean said:
22nd Oct, 2010 at 11:26:02pm
On 22nd Oct, 2010 Joe C said:
a bare A+ block is a weeny bit over 35kg (like 80 grams) So that's 35.08Kg or 35,080 Grams On 26th Oct, 2004 TurboDave16v said:
22nd Oct, 2010 at 11:39:00pm
yep, I'll double check monday, although i've drilled some holes in it now. On 28th Aug, 2011 Kean said:
22nd Oct, 2010 at 11:44:44pm
22nd Oct, 2010 at 11:47:56pm
new block for the 7 port, got a set of accralites and found they will be baggy in the block so going to go with a fresh one, just modding it for oil jets, a 4 bolt main, dry decking, etc On 28th Aug, 2011 Kean said:
22nd Oct, 2010 at 11:56:03pm
PROPPER MANS BLOCK Edited by Sprocket on 22nd Oct, 2010. On 26th Oct, 2004 TurboDave16v said:
