| Home > Help Needed / General Tech Chat > Cuts out on full throttle | |||||||
![]() 174 Posts Member #: 9041 Advanced Member Essex |
22nd Oct, 2010 at 05:33:01pm
Hi guys getting to a bit of a wits end now with the wifes motor.
![]() 716 Posts Member #: 9077 Post Whore Cheshire |
22nd Oct, 2010 at 05:42:12pm
I'd be inclined to think it was the head gasket. As the pressure increases with the increase in throttle, it can force the gases through a hairline crack in the gasket. On lower throttle the pressure isn't as high so could run normally. Edited by Mini_the_minx on 22nd Oct, 2010. On 2nd Nov, 2010 wil_h said:
I think it's probably a given that all people who own pink cars like it up the Gary. On 14th Jan, 2011 rubicon said:
please dont put a batty kit on it, il have to by internet law, Report you to barry boys.com |
22nd Oct, 2010 at 05:50:08pm
This is what i was thinking but hearing someone else say it just backs it up.Well suppose the head comes off tomorrow.. |
22nd Oct, 2010 at 06:08:38pm
Have you checked the timing? Is the vac advance connected and free to move inside the dizzy housing? On 11th Feb, 2015 robert said:
22nd Oct, 2010 at 09:54:28pm
sounds like a fueling issue to me. Is the engine standard and are you using a standard needle in the carb? http://www.twin-turbo.co.uk
547 Posts Member #: 2928 Post Whore peterborough |
22nd Oct, 2010 at 10:05:44pm
i 2nd bens diagnosis Jack Jones |
22nd Oct, 2010 at 11:13:50pm
Engine is standard apart from a stage 1 kit and a hif 38 carb. timing checked all ok. but is getting worse. there seams to be enough fuel getting up and misfire is slighty worse today. |
23rd Oct, 2010 at 09:47:51am
if it was head gasket it would run ok higher up but be rough low down, been there many times
Yes i moved to the darkside |
23rd Oct, 2010 at 10:19:29am
Dont seam to want to run with choke in or out this morning when trying to move it on the drive just fire's up pop's a bit smeels massivley of fuel but no bang. Plugs out cleaned checked still nothing the time it takes i think the head is coming off aint been off in 4 or more years. |
23rd Oct, 2010 at 10:28:24am
what colour where your plugs before you cleaned them? On 11th Feb, 2015 robert said:
23rd Oct, 2010 at 01:51:37pm
Change the condenser again - there are lots of very poor ones out there.
23rd Oct, 2010 at 02:10:49pm
Instead of debating about the head gasket, just do a simple compression test.
24th Oct, 2010 at 04:07:20pm
Sounds like over fueling to me not under, so pulling the choke out will make things worse.
388 Posts Member #: 442 Senior Member Manchester |
24th Oct, 2010 at 08:58:33pm
Im going with either:
