Home > General Chat > whats next?
blister
Member #: 2590
Croydon
this is my current spec, what do you lot think is a worth while mod?
for example poly bushes, more weight saving? anything you would recommend?
my current spec is as follows,
Engine spec:
1275 mg engine
eaton 45 SC (s/t) (10 psi)
hif44 (just a cone filter)
standard turbo head (minispeed)
standard dizzy leads and coil
minispeed 2 core rad and water wetter
inner wing fan (spi)
8.5 cr
body/structual
sunroof
every panel is metal
poly windows
no carpet
no soundeadening
no carpet
no winder mechs
7.5 alloy 4 pots
front and rear hi lows
all standard front and rear subframes
i cant think of anything else but has any of you got any suggestions in drivability. performance, and handeling?
oh bugger how could i forget that i got lowererd gaz adjustables all round with front and back fully adjustable negative camber kit
Edited by blister on 22nd Oct, 2010.
maccamcvey
Member #: 6673
Worral Sheffield
Mega jolt and as huge IC and up the psi?
blister
Member #: 2590
Croydon
suck throught i cant use an intercooler, :(
is megajolt really good because i got most of the parts for it i just need a few more bits,
i am looking for a thread on wanted where i was talking to minivan man think i will find it in a second
blister
Member #: 2590
Croydon
i have also got these wheels and tyres 10" with A032R i believe
http://www.minispares-online.co.uk/?cat_id...17&prod_id=2155
