Home > Help Needed / General Tech Chat > Light steel flywheel?
On the continuing quest to clear some space in my garages ive come accross a flywheel, from memory it came from a MED 1430 i bought but honestly cant be sure
Now it looks like a light steel flywheel but weighs 5.5kg (just over 12lb) from memory the standard cast jobbies are 25lb? and the ultralight around 8lb? , it has a removable centre not something i have seen in any i have bought
any thoughts of origin and what i should stick it up for?
quinton
Member #: 1911
Can you mix verto and pre verto parts. Cause I have pre verto ATM and wanna go to the rts setup but wanna use my bits if I can or possible by this?
this is ann A series wolfie pre 80s i believe, with the seprate removable centre, clearley has had some lightening done, i would hazard a guess £ 50 to 60
Same as in my 998 Cooper motor but lightened
