| Home > Help Needed / General Tech Chat > leaking turbo carb? | |||||||
301 Posts Member #: 2480 Senior Member Swindon |
24th Oct, 2010 at 01:52:41pm
Hi all. I topped up the dashpot on the carb the other day. After pottering around i later noticed oil had dripped onto the manifold and found oil on the bottom of the metal plate the throttle cable goes into. I wiped it clean and later checked to find more oil there again? I tightened up all the nuts/bolts holding the carb to the manifold. Is this normal? I didnt spill any and havent run the car since. Thanks feature=mhum |
![]() 338 Posts Member #: 1911 Senior Member Swindon |
24th Oct, 2010 at 02:03:27pm
Sure it's not your rocker cover gasket? |
24th Oct, 2010 at 02:17:38pm
yep. Thats all fine. The oil run on the exhaust manifold shows it dripping down onto it feature=mhum |
24th Oct, 2010 at 04:26:41pm
Breather pipe instead mate?? Drives
24th Oct, 2010 at 05:01:37pm
as you know how special i am paul, where is the breather pipe?! lol hows the job going? feature=mhum |
