| Home > Help Needed / General Tech Chat > Facet fuel pump Problems! | |||||||
![]() 558 Posts Member #: 8143 Post Whore London |
24th Oct, 2010 at 07:02:11pm
Hi.
24th Oct, 2010 at 07:14:36pm
This is my one and it works fine, i just put it on for a min then start the car.
24th Oct, 2010 at 07:20:20pm
So it doesn't need to be mounted at bottom of tank? I might take the regulator/filter off? Am I supposed to see the regulator filling up?
Edited by dischub on 24th Oct, 2010. |
24th Oct, 2010 at 07:35:03pm
yes mate has it worked before? is the filter clean in the pump.
24th Oct, 2010 at 07:41:19pm
Yeah the car has run before, just usually takes a few turns to get started but nothing was happening today.
24th Oct, 2010 at 07:56:38pm
right i am all most sure your reg is plumbed in worng. I have started posting on Instagram also my name on there is turbomk1golf
24th Oct, 2010 at 07:59:15pm
Hmm I have no idea to be honest, I think I saw the instructions for the reg in the spares box that came with car. If it was plumbed in wrong then surely it wouldn't run all them other times? I think its been running like this since the engine was rebuilt 20k ago.
24th Oct, 2010 at 08:12:02pm
Found the instructions for the Reg, the pipe/connection pointing down is the inlet and the other the outlet.
24th Oct, 2010 at 08:21:00pm
What carb do you run?
Edited by wil_h on 24th Oct, 2010. Fastest 998 mini in the world? 13.05 1/4 mile 106mph
24th Oct, 2010 at 08:40:20pm
They're twin 1.5" SU |
24th Oct, 2010 at 08:41:48pm
Have you actually checked to see if fuel is getting to the carb first? Pull a pipe off at the carb. On 19th Jan, 2010 wil_h said:
24th Oct, 2010 at 08:44:35pm
as above i would check the flow rate at the carb, then give the carb a good clean, check the float is at the correct level etc. Edited by MarkGTT on 24th Oct, 2010. |
24th Oct, 2010 at 08:47:36pm
I was going to do that but it started getting dark, I'll give it a try tomorrow!
24th Oct, 2010 at 09:43:29pm
Have you set the pressure in the regulator? Theyre not necessarily at the correct pressure, you want 4psi.
I seriously doubt it! |
25th Oct, 2010 at 05:15:34pm
Seems to have sorted itself? Gave the battery a quick charge and yanked the choke harder and it burst into life, so I'm guessing the choke cable is not pulling the choke out properly? I've got a new problem though, see Clutch rattling thread |
31st Oct, 2010 at 12:03:11am
Was still having problems so I took the Reg out today
Edited by dischub on 31st Oct, 2010. |
31st Oct, 2010 at 12:16:48am
Weber carbs can cope without a regulator but SUs are a bit fickle and need one if you have a high capacity pump like the Facet.
1st Jan, 2011 at 02:45:56pm
Right, got in the mini today. Last used yesterday. Would not start, complete pig just keeps turning over and over even with the jump pack. Took the spark plugs out, sparks ahoy so put them back in. Must be that bloody fuel pump at the back not pushing enough fuel. Come up with a quick plan, get a spray bottle and fill it with unleaded, take the filter off and squirt some of that stuff into the carbs. Get back in roars into life as I would suspect, so squirt some more down and start keeping the revs high in hope it will bring the fuel from the tank and it done the job.
1st Jan, 2011 at 07:25:59pm
regulator should always be after the pump On 26th Oct, 2004 TurboDave16v said:
25th Jan, 2011 at 07:58:24pm
Finally worked this one out and I feel like a tit!
