| Home > General Chat > am i losing my mind | |||||||
![]() 871 Posts Member #: 2590 Post Whore Croydon |
24th Oct, 2010 at 07:13:55pm
i just found a thread which i am not sure if i read correctly but i have now lost the thread (laptop lost battery)
24th Oct, 2010 at 09:04:17pm
Its a basic rule, that you can achieve similar improvement in acceleration by either removing weight from the car, or, by removing weight from the rotating parts of an engine. the difference between the two is not as clear cut as some will have you believe. However, for the sake of argument, if you removed 1kg of weight from the rotating parts of an engine, similar gains could be had by removing 10kg from the car, yet the engine has produced no extra HP. On 26th Oct, 2004 TurboDave16v said:
24th Oct, 2010 at 09:07:02pm
so say if i fitted a lightened flywheel (minispeed £35 exchange one) and a alloy back plate how much weight will i save also what performance gains can be confirmed on 10kg of body weight? |
24th Oct, 2010 at 09:38:37pm
You wont see any major gains to talk of from losing 10kg of body weight, but if you fit a good lightweight flywheel you will notice engine response which will give a small improvement in accelleration.
I seriously doubt it! |
24th Oct, 2010 at 09:53:44pm
On 24th Oct, 2010 blister said:
so say if i fitted a lightened flywheel (minispeed £35 exchange one) and a alloy back plate how much weight will i save also what performance gains can be confirmed on 10kg of body weight? Unless you are on an extreme weight saving you will see little benefit from the alloy backplate. The only gain in general terms is by loosing weight from ROTATING engine components. when you start getting to the extremes of weight saving, EVERY little bit counts. The backplate on its own will do nothing for performance. That is not to say it is of no benefit!! Paul, while the numbers I quote may not be correct the theory is. while the engine produces no extra HP, fitting a lighter flywheel, the HP that would have been absorbed (stored) accelerating the rotating parts of the engine, is now freed up and can now be seen as improvement of acceleration of the car. Likewise, removing weight from the car frees up HP and can be seen as an improvement in acceleration. the 10:1 ratio car:engine weight saving, was just as an example and should not be considered as fact! On 26th Oct, 2004 TurboDave16v said:
24th Oct, 2010 at 09:59:48pm
Sproxter, my answer wasnt aimed at what you had said, rather, just pointing out to Mr Blister that theres no 'exact' science to it
24th Oct, 2010 at 10:06:36pm
On 24th Oct, 2010 paul wiginton said:
Sproxter, my answer wasnt aimed at what you had said, rather, just pointing out to Mr Blister that theres no 'exact' science to it Paul Appologies:$ On 26th Oct, 2004 TurboDave16v said:
24th Oct, 2010 at 10:09:56pm
Sproxter, my answer wasnt aimed at what you had said, rather, just pointing out to Mr Blister that theres no 'exact' science to it Paul Appologies:$ Completely unecessary mate :) I seriously doubt it! |
