Home > Help Needed / General Tech Chat > what amp fuses to use?
matt-atude
Member #: 8913
seaford, east sussex
hi all, im running a emerald ecu and i want to know the best amp fuse for the following jobs:
12v supply to ecu. currently using a 25 amp
12v supply to coil pack and injectors
12v supply to fuel pump
cheers
matt
almichie
Member #: 2065
It's an easy equasion, it's called ohms law. You divide watts consumed by voltage. So let's say you consume 10 watts. At 12VDC it's 0.83 Amps. At 14VDC it's 0.71A. At voltage increases current drops. You need to know the wattage of each bit of kit then work out the current then either at 50 or 100 percent for fuse size.
Shaft seems nice and snug
Ben H
Member #: 184
Melton Mowbray, Pie Country
This is totally wrong. A fuse protects the wire feeding the device not the device its self. You need to know that size of cable you are using as that will determine the maximum fuse you can use.
http://www.twin-turbo.co.uk
Jason G
Member #: 1459
En-suite user
Braintree, Essex
I would of thought a ECU and injectors would only be a couple of amps at most to be honest. 25amps far too high.
On 19th Jan, 2010 wil_h said:
quinton
Member #: 1911
As Ben says. A fuse is to protect a fire being started which is caused by over current on a wire so therefore you fit a fuse to protect is. For 2.5mm you run 20 amp and 1.5mm 15 amp. And so on with bigger just run a bigger fuse.
almichie
Member #: 2065
What your saying is correct for 230v AC, not DC and not 12V. Yes the fuse protects the wire but the fuse also needs to be able to blow should the device or wire go faulty. Of it doesn't the device will catch fire as easily as the wire...
almichie
Member #: 2065
I take some of it back...
http://www.energy-solutions.co.uk/cable_conductor.html
Take a look for direct current applications and cable sizing
quinton
Member #: 1911
As I said. Now that's assuming maximum current for clipped direct cables with free flowing air around. So drop the fuse sizes to what I said and your sorted.
matt-atude
Member #: 8913
cheers for the advice just looking through the emerald wire diagram noticed it says use a 2 amp fuse (optional) the loom came from emerald so im guessing 2 amp it is, it just sounds like a very small rating.
cheers
matt
