Home > For Sale > VDO gauges
t3gav
Member #: 229
Gavin@minispares.com
kent
Hello, i've had a change of plan and decided to use a digi dash so my old gauges are up for sale. They are still in the box never used:
80mm electronic speedo
66mm boost gauge shows vac and boost up to 25psi
66mm mech oil pressure
66mm water temp (fahrenheit)
These are similar to what Phil used in his car:
After £220 delivered anywhere in the UK, would rather not split as they all match.
t3gav
Member #: 229
kent
Some better pics:
do they come with senders etc?
t3gav
Member #: 229
kent
I have 1 tubing kit for the oil pressure or boost gauge, the water temp gauge comes complete, you would need a sender for the speedo and 1 more tubing kit.
dischub
Member #: 8143
London
Might be worth putting it up on 16v site too buddy because of the electric speedo
whats the point of a boost gauge only going to 25psi, come on lads, run a mans amount of boost!!!
Edited by Jimster on 1st Nov, 2010.
Jason G
Member #: 1459
En-suite user
Braintree, Essex
A gauge that went up to 8 would be nice! Posh b**t**d! *wink*
On 19th Jan, 2010 wil_h said:
t3gav
Member #: 229
kent
Now £200...
Bargain!!!! how much where these new???
t3gav
Member #: 229
kent
Cost me over $350 but from the UK they were £300+ from memory.
t3gav
Member #: 229
kent
Any interest if i split? £80 for the speedo, £40ea for the others...
t3gav
Member #: 229
kent
Speedo provisionally sold.
t3gav
Member #: 229
kent
Bump :)
dischub
Member #: 8143
London
Speedo still for sale?
