Home > Beginners Tech > Pistons suitable or not
wolfhound
Member #: 7081
Durban KZN - South Africa
Hey guys
I've posted this under my other topic, (T3 or smaller)
But i have a set of good (used but nearly new) 9.4-1 std 4 ring pistons on innno rods. I think (with my GM 1600 Turbo experiance) i want to aim for 8.8-1 compression, so i will have to open
Should i bother using thes pistons ? aiming to run car up to around 0.7 to 1 bar (10-14 PSI IIRC) if possible,
or
Should i just save up for some forged ones ? (sell a kidney or two)
Check out the South African Mini Forum
www.atfreeforum.com/kznmini
Personally I wouldn't use the old 4 ring pistons. Good quality cast pistons are up to the job.
Also not sure what import duty is like for SA but Avonbar are doing forged accralites for £300 at the moment.
wolfhound
Member #: 7081
John, ta for the adivice there. I just orderd a shed load of stuff from Rich @ MSC North, got shippped off yeterday. Will go look at the Avonbar site.
Thanks again
use the accralite, as john says
in my book there the best pistons for the A series available,
omega cast pistons should be more then up to the job for a 14psi application.
For the cost its not something I'd take a chance on.
wolfhound
Member #: 7081
ta for the advice guys. Looks like i may have sold my old stock 4 ring pistons. If the deal gets done, the it's a set of the accralites for me.
