| Home > Wanted > Timing cover with no breather | |||||||
29th Oct, 2010 at 03:20:25pm
Hi lads,
29th Oct, 2010 at 03:51:23pm
Easy enough to chop the breather off and weld a plate over it if you can't get one.
29th Oct, 2010 at 03:51:43pm
Yep, got a couple. I'll pick you a decent one, no charge, just postage. Fastest 998 mini in the world? 13.05 1/4 mile 106mph
29th Oct, 2010 at 04:08:44pm
Top man wil let me know how much you need. I have started posting on Instagram also my name on there is turbomk1golf
29th Oct, 2010 at 04:47:02pm
Sorry to butt in gents but why do you want to run without a breather ?, are there for and against stories for these , is there a need for the breather.
29th Oct, 2010 at 04:51:55pm
Its so i can fit a intercooler in there. But don't tell any one I have started posting on Instagram also my name on there is turbomk1golf
29th Oct, 2010 at 05:39:51pm
Just because the breather canister has been removed/isn't there it doesn't mean that you can't have a breather on it On 11th Feb, 2015 robert said:
29th Oct, 2010 at 05:44:07pm
As long as there is a breather on the flywheel housing and the rocker cover, then this is not needed.
29th Oct, 2010 at 07:52:25pm
Will you claim intellectual rights? is so this may be an issue for them to be made.
On 29th Oct, 2010 wil_h said:
As long as there is a breather on the flywheel housing and the rocker cover, then this is not needed. All those running with no dizzy could also use this hole for a breather. Maybe someone could make a bung with a hose on for the dizzy hole. Crystal Sound Audio said:
29th Oct, 2010 at 08:07:09pm
hahahaha
On 29th Oct, 2010 wolfie said:
Will you claim intellectual rights? is so this may be an issue for them to be made. On 29th Oct, 2010 wil_h said: As long as there is a breather on the flywheel housing and the rocker cover, then this is not needed. All those running with no dizzy could also use this hole for a breather. Maybe someone could make a bung with a hose on for the dizzy hole. Fastest 998 mini in the world? 13.05 1/4 mile 106mph
