| Home > Help Needed / General Tech Chat > yes an other fueling problem | |||||||
282 Posts Member #: 1404 Senior Member The Netherlands |
30th Oct, 2010 at 08:04:55pm
there is nothing wrong with a A-series that a turbo can't fix.
30th Oct, 2010 at 08:20:08pm
you should not use a rising rate reg with a carb, you need a fixed rate regulator like the standard metro turbo item. turbo 16v k-series 11.9@118.9 :)
30th Oct, 2010 at 08:29:33pm
the pump isnt an issue. Choice of FPR is.
30th Oct, 2010 at 09:28:45pm
I starting to think if i said the right thing about the regulator.
30th Oct, 2010 at 10:44:43pm
FPR012 would be suitable,m although the term "rising rate" can be misleading and confusing.
31st Oct, 2010 at 08:22:58am
FPR09/012 it's the one i have.
31st Oct, 2010 at 08:33:44am
I think you need to get the fuel pressure set at the regulator. If it's too high it will just overwhelm the float valve. On 11th Feb, 2015 robert said:
31st Oct, 2010 at 08:35:02am
One thing i'm not sure about is the fine red writing at the bottom of the page.
31st Oct, 2010 at 08:44:16am
5psi might be ok, but without a gauge in there to measure the fuel pressure, you could have it set much higher. In the 13's at last!.. Just |
31st Oct, 2010 at 09:17:58am
In my experience so long as it is not being forced passed the needle valve it is fine. Setting the FPR pressure to 3/4psi is not critical, but it does have to be at least 3/4psi. I have successfully set the pressure with this (perhaps bodgy way)
http://www.twin-turbo.co.uk
31st Oct, 2010 at 05:38:43pm
On 31st Oct, 2010 paneermeel said:
FPR09/012 it's the one i have. At the moment i don't know what the pressure is. I don't have a meter to check it, yet
When i put the carb back together i blew as hard as i could and it did not leak any air. When i lifted the float is started to let some air pass. I don't know for sure if this was the correct way to check it but it is the only way i could think off If you can blow more than 1psi, I'll be surprised. Needle valve will barely hold 5psi. So first obvious thing to do would be to see what fuel pressure you actually have. You're wasting your time otherwise. 9.85 @ 145mph
31st Oct, 2010 at 06:11:26pm
I did some checks i can do without a meter there is nothing wrong with a A-series that a turbo can't fix.
1st Nov, 2010 at 06:11:34pm
On 31st Oct, 2010 stevieturbo said:
So first obvious thing to do would be to see what fuel pressure you actually have. You're wasting your time otherwise. I got a meter today and i measure 3,5 psi
So the fuelpresure is not the problem at the moment. Since there is no fuel coming out of the carb when you remove the dashpot i would expect the needlevalve closing. So i am suspecting the floatheight. If the fuel level drops in the floatcamber it runs better. Only thing what contradicts this the rebuild guide who i telling me i should allow the fuel level to get 1 mm higher. If someone can explain me this before i put everything together would be perfect
1st Nov, 2010 at 08:00:57pm
Does the piston move up and down freely in the dashpot chamber ?
1st Nov, 2010 at 08:23:45pm
On 1st Nov, 2010 stevieturbo said:
Does the piston move up and down freely in the dashpot chamber ? And float height doesnt seem to have a massive impact on running. More likely it's either a spring, oil or simple mixture setting ( needle/jet height ) issue then The piston moves freely, the engine responds fine to the funpedal
I now tried reving the engine and then attached the + of the pump. It immediately starts to run rough and it smokes a lot. I also lowered the floatheight but the problem is still the same. The way i think it is getting to much fuel, but why? The strange thing that i can not explain is when i disconnect the pump and feed the carb just with a tube the problem is still the same. The needlevalve should hold that easy. How can i test the needlevalve? I tested myself and i blew just short of 2 psi on the meter. The needlevalve is holding that when i hold the carb up-side-down. there is nothing wrong with a A-series that a turbo can't fix.
1st Nov, 2010 at 08:50:29pm
next to the fuelfeed is a pipe you should block off. I removed the plug and started the pump. Fuel flowed out of it? I don't know if this is normal?
2nd Nov, 2010 at 06:38:17pm
On 1st Nov, 2010 paneermeel said:
I don't know if this is normal? I'm hoping this could help to get to a solution. anyone?? there is nothing wrong with a A-series that a turbo can't fix.
2nd Nov, 2010 at 08:26:54pm
ok,
2nd Nov, 2010 at 11:53:47pm
So...explain very clearly what the problem is.
3rd Nov, 2010 at 11:46:07am
On 2nd Nov, 2010 stevieturbo said:
So...explain very clearly what the problem is. - ok:) All I have picked up so far, is that it doesnt idle ? - it' idle's en runs but only WITHOUT the fuelpump working. When it is getting fuel it starts to splutter and stops. If i rev it a lot i can keep it running for some time. But is smokes a lot. Have you adjusted the mixture screw ? - is 2 turns out according to the rebuildguide, i have not touched it yet(read below) Does the choke work ? - must check this tonight Has someone competent looked at the car ? ie with an ability to diagnose problems ? - i'm the only one who has looked at the problem. and knews somethings about cars but this is mine first engine build so i am learning along the way. I talked about mine engine problems with a mechanic and i have one thing i must check. You also suspected the mixture. If i screw the mixturescrew in i lift the needletube slightly higher above the fuellevel in mine carb. This could explane why it runs better when i disconnect the fuelpump and the fuellevel drops. it wouls also explaine why it is starting perfectly without i even touching the choke. With the fuellevel that i have now in the carb it's always choking. Tonight it's the first thing i am going to try. I will keep you informed there is nothing wrong with a A-series that a turbo can't fix.
3rd Nov, 2010 at 08:47:42pm
YIP YIP HOERA it run's.
