Home > General Chat > Profec E-01 BOOST Controller. any good guys?............
have seen this on Ebay just wondering has any one got one. used one?
any feed back would be great
*happy*
on EBAY
PROFEC E01 EO1 E-01 BOOST CONTROLLER Item number: 7957621795
Edited by BENROSS on 27th Feb, 2005.
ministef1
Member #: 1791
Cranleigh, surrey
i've got one and it seems to be very good, but i've had some trouble setting it up and not a lot of people know about them, its reading too high on the rpm so any boost settings i map in are out of sync as such?
"Cars are a lifetime of pain"
evolotion
Member #: 83
Glasgow, Scotland
shite, avcr blows it away x10000000000000
am running an avcr, have set near actuator pressure in first gear, .8 bar in second 1 bar in third and over a bar in 4th and 5th. you can also use the avcr to controll how quick the boost coems in to an extent, brilliant if your cars boost hits in hard and you need to slow it down a bit. the e-01 only really comes into its own as a display when used in conjunction with an e-manage blue. :) and the emanage blue isnt all that good either compared to the ultimate.
to make the most of teh avcr you need a speedo input and a TPS. :) as well as an rpm signal, and if you choose a scramble swithc for selectable over / under boost.
Edited by evolotion on 11th Jun, 2008.
Denis O'Brien.
sounds like a hell of a boost controller.
To google i go *happy*
