Home > Help Needed / General Tech Chat > Bertie the dirty mini 30
failed her MOT
Hazards work but flashers dont ?
if you flash hi beam nothing happens but if you push stalk forward for high beam you loose lights ?
also failed on wheel bearing, brake imbalance, 0% handbrake and a few other bobs and bits these have been done today
sauber 200
Member #: 245
you have two flasher units on your car,one for
flashers one for indicators,one is under dash
drivers side the other as you know next to wiper motor.or it could be your stalk which also operates your high beam.
Nick
Member #: 154
Midlands
had the same with my main beams too dude, turned out the bullet conectors under the slam panel weren't making a good contact and i think the alternator had started eating a couple of the wires down there aswell.
your hazard problem is down to a blown fuse, there are 2 inline fuses under the scuttle panel in seperate holders, one of these is for the hazards
its flashers mate
need to have a look tomorrow cant get the entusiasm to be honest
oh ass, oh well its there for the record
looks like the stalk is bust
nice easy one.
