Home > General Chat > safe boost to run without fmic?
bennyy
Member #: 9037
Doncaster, yorkshire
Running standard boost at the moment, and wanting to turn it up a little, what is a safe boost level without running an intercooler?
On 15th Mar, 2012 wil_h said:
On 30th Apr, 2012 Brett said:
That depends on compression ratio, Temps, Fuelling, Timing etc.
jamz
Member #: 2292
Tool
Herne Bay, kent
i wouldnt run anymore than 7 without any mods tbh. if your car is perfectly set up 10 would be fine.
cant beat a good blowout.
bennyy
Member #: 9037
Cars getting set up on RR on saturday so fueling and timing should be spot on, will 8psi be safe enough? , is their any way of running an intercooler without removing the front grill?
Edited by bennyy on 4th Nov, 2010.
Have a look at some build threads. You can get a quite substantial intercooler in without having to loose the grille.
wintersurferuk
Member #: 2208
unknown compression ratio and running without an intercooler, i wouldnt bump it up to much mate.
get the carb set up, drive it till you get an intercooler, then enjoy the boost! :) i could be talking out my bum, but then i like to play safe
Doesnt have to be front mount, could always get a front mount rad to keep temps down and go side mount like nic did *smiley*
bennyy
Member #: 9037
how much work to fit an intercooler? i know i need to modify my plenum chamber? and i obviously need an intercooler and pipe work, anything else?
wintersurferuk
Member #: 2208
i got most of my pipe hose from a scrap yard, 5£ :)
Cable ties and gaffer tape best way to fit anything!
fab
Member #: 100
Parisien Turbo Expert
Paris\' suburb
in your case I would use a bit of water injection to clean the upper boost of det.
8 psi is the max safe limit that you can use , then anything wrong (hot day bad tank, engine a bit hot..)= piston kiss
then if you use an 8 psi trigger with WI you'll tun safely up to 12 psi (it is where the a seri come to live), there is an engine tone/note above 700g/11 psi that make you feel right.
bennyy
Member #: 9037
Never heard of water injection, will do a bit of reading on that, what's involved and what will I need?
was going to buy an intercooler few months back, but didn't feel confident doing my own plenum chamber, are they easy to come by? That suits both dump valve and intercooler?
fab
Member #: 100
Paris\' suburb
Edited by fab on 6th Nov, 2010.
fab
Member #: 100
Paris\' suburb
link:
http://www.aquamist.co.uk/vbulletin/
wintersurferuk
Member #: 2208
hacksaw+plenum chamber= done.
or see if theres anyone near you with a tig, or buy one of the nice shiny ones, i think mat does them. lovely jubbly!
Have a read of this before going with water injection.
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=356563
Bad advice in my opinion.
1972-ANGUS
Member #: 3894
sallys gap. garden of Ireland
On 5th Nov, 2010 fab said:
WI use a trigger at which a high pressure pump will deliver a fine mysth in the piping
OOH! a fancy mist in da piping! DOH!
fab
Member #: 100
Paris\' suburb
bennyy
Member #: 9037
Got it set-up yesterday at bog brothers, north yortkshire, very good, definstely worth the hour and half drive, would reccomend them to anyone, made 96bhp, he said that was at the wheels? Can't see how it would make that sort of power with a standard turbo engine?
Anyway will be ordering a manual boost controller this week and a decent boost gauge, decided on running about 8psi for the time being, then getting antercooler and turning it up some more *happy*
bennyy
Member #: 9037
Decided I am now going to run an intercooler, looking at threads etc trying to get ideas for sizes/location.
Am I right in thinking one pipe goes from one side of the intercooler to the turbo and the other pipe goes from the other side to the plenum chamber? Or is there more to it than that?
You got it benny boy!
bennyy
Member #: 9037
Thanks mate, thought it was that, just wanted to check, is their anyone on here who does plenum chambers modded for dump valve and cooler? Don't fancy attempting it myself
PM giallofly
PM Giallofly aka Jon Flanigan. He's the man for modding metty plenums.
Or if you get the horn for shiny things pm Nic for one of his and Hywel's Plenums of sexyness. £120 posted I think?
