Home > Help Needed / General Tech Chat > pinion bearing retainer
clubbie70
Member #: 8935
netherlands
hi all,
got a DAM5626 gearbox case, wich has a pinion bearing retainer thats only supported by 3 bolts.
Would it be wise(or even possible) to drill an extra hole in the gearbox and tapper it, so that i can mount it with 4 bolts?
thanks
No,
The DAM5626 casing was made specifically without the fourth hole because that's where the earlier casings cracked - though that bolt hole.
Leyland/Rover just didn't bother re-manufacturing the retainer plate to make it look like it matched :)
clubbie70
Member #: 8935
netherlands
thats fast .....:)
so, that means the 3 bolt casing would be stronger...?? and best to use with a modified engine instead to the other casings...
On 5th Nov, 2010 clubbie70 said:
thats fast .....:)
Yes:)
Like he says :)
If you had a DAM2886 to put alongside it you would also see that, as well as the deleted bolt hole, the casting in that area has an exra strengthening ridge on the DAM5626.
