| Home > Technical Chat > Turbo Exhaust Theory | ||||||
5th Nov, 2010 at 02:31:08pm
Found this. Thought I would share it here.
248 Posts Member #: 7936 Senior Member DK-8450 Hammel. Denmark |
5th Nov, 2010 at 04:43:30pm
Thanks.
If i have more toys than you when i die, I WIN |
5th Nov, 2010 at 05:08:27pm
Interesting,
5th Nov, 2010 at 06:19:33pm
Interesting read, and that satisfies my decision to run a 2.25" downpipe and system which is pretty much the ID of the turbine outlet on the GT17. we know the bigger exhaust gives better results from Roberts experience with his side pipe at the dyno shoot out. The effortI also put in to my manifold looks like it might be worth something too.
5th Nov, 2010 at 07:13:13pm
i Designed and made my LARGE! single exhaust on the Benross machine made severall years ago
5th Nov, 2010 at 08:10:51pm
It's as simple as bigger is better, especially close to the turbocharger itself. 9.85 @ 145mph
![]() 1596 Posts Member #: 8027 Post Whore Thrapston, Kettering, Northants NN14 |
5th Nov, 2010 at 08:56:45pm
ive opted for a 2" downpipe which imidiatly goes three inch from there backward. On 17th Feb, 2011 apbellamy said:
I popped my first one out the other day... |
6th Nov, 2010 at 09:59:20am
It made me thing that the 1.75" exhaust on the van will start to be a restriction if/when we push for more power. I reckon a home brew 2" is on the cards On 11th Feb, 2015 robert said:
6th Nov, 2010 at 11:36:31am
side pipe ala challenge cars?
On 6th Nov, 2010 apbellamy said:
It made me thing that the 1.75" exhaust on the van will start to be a restriction if/when we push for more power. I reckon a home brew 2" is on the cards On 28th Aug, 2011 Kean said:
6th Nov, 2010 at 11:37:29am
You got it! If something is worth doing, it's worth doing half of. |
6th Nov, 2010 at 11:46:15am
On 5th Nov, 2010 Rick.SPI said:
ive opted for a 2" downpipe which imidiatly goes three inch from there backward. A 3" downpipe then dropping to 2" would make more sense. Bigger is better as close to the turbo as possible for as long as possible. 9.85 @ 145mph
6th Nov, 2010 at 12:06:52pm
On 6th Nov, 2010 Joe C said:
side pipe ala challenge cars? On 6th Nov, 2010 apbellamy said: It made me thing that the 1.75" exhaust on the van will start to be a restriction if/when we push for more power. I reckon a home brew 2" is on the cards 2" from the turbo back with a smallish free flow box towards the rear of the tunnel and a nice shiny round end popping out through the passenger side sill. On 11th Feb, 2015 robert said:
6th Nov, 2010 at 12:10:18pm
Upstream of the turbo, it's a different matter altogether:
6th Nov, 2010 at 04:47:11pm
On 6th Nov, 2010 Paul S said:
Upstream of the turbo, it's a different matter altogether: "For turbo cars, you throw all that out the window. You want the exhaust velocity to be high upstream of the turbine (i.e. in the header). You'll notice that primaries of turbo headers are smaller diameter than those of an n/a car of two-thirds the horsepower. The idea is to get the exhaust velocity up quickly, to get the turbo spooling as early as possible. Here, getting the boost up early is a much more effective way to torque than playing with tuned primary lengths and scavenging. The scavenging effects are small compared to what you'd get if you just got boost sooner instead. You have a turbo; you want boost. Just don't go so small on the header's primary diameter that you choke off the high end." I would read that as the primarys being smaller than a tuned N/A car rather than an production car, On 28th Aug, 2011 Kean said:
8th Nov, 2010 at 09:03:20pm
I have run my own design of 2.5" onto a 4 1/4" oval for many years now always thought the playmini downpipe was one of the choke points and that proves my thinking correct. Own the day
