| Home > Help Needed / General Tech Chat > just wondering | |||||||
621 Posts Member #: 393 Post Whore Oulton Park |
28th Feb, 2005 at 09:30:47am
The dumpvalve the pipe that comes off the top where that go if you haven't got the avonbar spacer? |
28th Feb, 2005 at 10:19:24am
The small pipe from your dump valve wants to go on the engine side of your carb butterfly and the boost gauge idealy wants to be on the intake manifold.
28th Feb, 2005 at 02:15:07pm
so you've got three nipples om the left side of the xarb pleuim then the one you block and then fuel in. then you u've got like two on top which i've joined together and another one that goes to the dizzy (carb butterfly) ??? intake??
28th Feb, 2005 at 06:30:28pm
check out carb connections, think you'll find the info in there. |
28th Feb, 2005 at 06:31:52pm
majic, here's my old setup
![]() 2641 Posts Member #: 19 Post Whore newcastle |
28th Feb, 2005 at 07:00:53pm
must have been a nightmare to start , iain. Everyone knows that instructions only have to be read if the thing doesn't work....
28th Feb, 2005 at 08:25:42pm
28th Feb, 2005 at 08:35:39pm
lol bet it overheated too Previous Engine: 1040cc Morespeed engine, 1275 turbo head T2 Turbo Mirage Manifolds Megajolt
28th Feb, 2005 at 08:49:37pm
ran cool, temp gauge didnt move..... |
28th Feb, 2005 at 08:53:16pm
i see your running 5 spark plugs, did it give extra power? |
28th Feb, 2005 at 08:54:05pm
thanks but what happened to the brake servo and where does the other side that T go to |
28th Feb, 2005 at 08:55:27pm
sorry boost gauge |
28th Feb, 2005 at 09:06:35pm
brake servo, what you need one of those for?! lol!
Edited by iain on 28th Feb, 2005. |
2nd Mar, 2005 at 11:52:39pm
I use a brake servo and run my boost gauge and dump valve from it. I just used a T piece before the 1 way valve on the servo - problem solved. |
