Home > Help Needed / General Tech Chat > boost gauge and megajolt take off vaccum
blister
Member #: 2590
Croydon
i have come to the stage now of where i am after plumbing in my boost gauge that shows vaccum and boost
i also am after plumbing in my Map sensor pipe that goes to megajolt
so my question is where do i put my take offs?
on the inlet manifold
blister
Member #: 2590
Croydon
is that for both then? as i have a take off on my carb (hif44) will this not work with megajolt?
yes.
No good on the carb as it is the wrong side of the butterfly. needs to be as close to the engine as possible
Edited by apbellamy on 7th Nov, 2010.
This has been covered so many bloody times!
You need to take them after the butterfly. None of the carbs take-offs are before. Tap the manifold or use one of the special spacer.
blister
Member #: 2590
Croydon
so megajolt (on special plate just after carb before supercharger)
and vaccum/boost gauge after the supercharger
No no no.
the megajolt has to "see" what the engine is seeing, ie the pressure in the inlet manifold.
the same with the boost gauge,
plumb them both in after the charger, you can use one take off and a tee peice.
blister
Member #: 2590
Croydon
ok mate thank you,
carred
Member #: 9412
Austria
I know this thread is old as hell but would the following spacer with integrated take-off work just as well to give my MAP sensor the correct values?
http://minispares.com/Product.aspx?ty=pb&pid=36947&au=1
Yes
carred
Member #: 9412
Austria
On 29th Nov, 2011 apbellamy said:
Yes
Thanks for your reply, I'll get one of these spacers then.
