Home > General Chat > Cold Starts
madcatminis
Member #: 5327
Dudley, West mids
It's been a cold one today don't you think. Winter is on it's way. *frown*
Started the mini up today wasn't much of a struggle but it was for the oil pressure. It seemed like forever to rise, once it did it was fine. Later in the day I decided to do a little timing test. From cold (and I mean sitting for 9 hours) it took 14 seconds for pressure to show on my TIM Mechanical Gauge. Once I got back home I knocked the engine off waited 5 minutes and restarted. This time the pressure took 3.5 seconds to show.
The oil that is currently in is Millers CTV 20-50. I'm assuming that as my gauge is the last thing to recieve oil pressure then thats why I'm getting a delay.
What are your gauges reading gents?
dischub
Member #: 8143
London
I think the Tim gauge is useless for accuracy, my mini has one at the moment, going to change it for a smiths when I get the chance.
my last 1275 was the same, i put it down to very thick oil and warn oil pump, b/e + mains bearings,
Johnny
Member #: 6926
Accrington
mine takes a while, a lot longer than usual. id say about 6 seconds (with a bit of revving to 1.5k)
madcatminis
Member #: 5327
Dudley, West mids
It would more than likely rise faster with a little throttle but I tried just with the choke out to give me an idea.
Star Mag
Member #: 375
Leicestershire
The oil drains out of my gauge over time and is slow to build pressure on first start, check the oil light goes out when it's started. If it does I wouldn't worry about it.
Also try bleeding the gauge. I found my smiths gauge took aaaages to respond. When i bled the line to it it whipped over in no time.
Ben H
Member #: 184
Melton Mowbray, Pie Country
I am guessing that the light is not on for all that time?
http://www.twin-turbo.co.uk
madcatminis
Member #: 5327
Dudley, West mids
I haven't got a light on my dash as I couldn't find anyone that sells the bulb holder.
