Home > Help Needed / General Tech Chat > 21251 + 60 piston help
eden7842
Member #: 8852
leicestershire
hey wats dish cc could i take these too? And wat psi wuld they take or have i just gota find out :p ↲
cheers eden
It doesn't matter as they are shite pistons and you will not want to use them in turbo engine.
eden7842
Member #: 8852
leicestershire
any other opinons?
They are budget pistons, at a minimum use 21253s. Try Hypatecs i run those and they are cheap as chips.
eden7842
Member #: 8852
leicestershire
oh right where can i buy them from?
mini spares austrailia
don't you mean Minisport Australia?
nope *wink*
Not sure what that means, lol
*Yes*
eden7842
Member #: 8852
leicestershire
so where they from? In england
If you want Hypatec, you buy from Australia
Or you could call Minispares North as they stock some of the sizes.
Vegard, if I didn't know any better I would have said you worked there *hehe!*
eden7842
Member #: 8852
leicestershire
am i right im sayin that with a 1340 id be gainin 16.25 cc in each cylinder
Plus 60 is 1330 not 1340.
Where does 16.25 come from? Just buy some omega pistons and have done with it, then get the head modified to sort the compression.
eden7842
Member #: 8852
leicestershire
head is done and i carnt afford omega unless someones got some second hand
there is a set of +20 Hypatecs available in the forsale section if you dig deep enough.
Check out one of the for sale posts by Paul S. They might still be available if Robert hasn't got his grubby mitts on them
I'm on commission :)
