Home > For Sale > Salisbury S/C LSD inc Hardy Spicers - Lincoln
zomerzet
Member #: 8383
Lincoln
I have a Salisbury Limited Slip Differential for sale from my turbo engine. I'm selling to help raise some cash for my new build.
*It comes with straight cut Crownwheel (64 teeth - Fitted) and pinion (14 teeth) giving a 4.57:1 final drive. RRP £150+
*Hardy Spicer Outpit Flanges x 2 RRP £15ea
*Hardy Spicer drive couplings x2 RRP £100ea
*Diff Bearings Fitted
*Diff end covers x2 (One has a cracked portion but I never got any leaks)
The diff is adjustable so you can adjust how much ramp you require. I'm unsure of the current ramp fitted. The same diff is for sale for £646.46 for a recon unit only at Minispares.com
http://www.minisport.com/mini-spare-parts/info_MS3321.html
I'd like £500 for the lot. You have everything you require here to fit an insane LSD into your mini and power around the corners!*happy*
If you're not accelerating or braking, you're wasting your time - Stirling Moss
An insane LSD??
Sounds interesting...
zomerzet
Member #: 8383
Lincoln
Well, in the world of mini differentials, The LSD is the highest specification available. I'm happy with a cross pin for road use.
Yes, but for real, is it insane?
