| Home > Help Needed / General Tech Chat > gear linkage rollpin removal | |||||||
1st Mar, 2005 at 12:33:23pm
getting engines out...ball joints doddle,gettting the roll pin out allways takes me about half hour why??? Is there an easy way
1st Mar, 2005 at 12:37:00pm
Put it in reverse gear, this gives it the ideal angle.
1st Mar, 2005 at 12:37:38pm
use a roll pin punch, put it in reverse, give it a fucking big smack. then when you come to put it back in use a small cap head head bolt with a nylock nut instead On 20th Oct, 2015 Tom Fenton said:
1st Mar, 2005 at 12:38:07pm
1st Mar, 2005 at 12:54:42pm
I always use a 4" nail with the end ground flat.
1st Mar, 2005 at 01:44:52pm
there must be an alternative to the roll pin, i always struggle with this stupid paitence exercise |
1st Mar, 2005 at 01:46:54pm
Why does everyone find this so hard!!!
1st Mar, 2005 at 02:49:08pm
1st Mar, 2005 at 03:08:30pm
Flash git |
1st Mar, 2005 at 03:28:52pm
I got a proper punch,but it's hard getting it square,the axle stand is always in the way and the hammer hits the subframe when you go backwards then the punch slips off again.....
1st Mar, 2005 at 03:33:58pm
Joys of having a pit!! not as good as a full ramp mind. done a few under the car and its not too bad. |
1st Mar, 2005 at 06:34:11pm
On 01/03/2005 15:28:52 Dangerous said:
........the axle stand is always in the way......... put it somewhere different then?!!
1st Mar, 2005 at 08:15:47pm
an alternative to the proper punch, that i use, and prefger... get a set of "jewlers screwdrivers" one of them will fit snugly INSIDE the roll pin, and have an edge that butts up against the rol lpin, cause of the legnth thats inside the roll pin it holds its position and doesnt fall out, so you can get all your fingers out the way for a good "hands free" battering with a 4lb lump hammer :)
1st Mar, 2005 at 10:30:12pm
hmm, is there a suitably sized R clips available for this job?????
