Home > General Chat > Plastic Front Ends
Can anyone recommend a decent 2 piece fibreglass front with integrated a-panels. (i want to keep the seam)
Fibreglass is gay. That Mike Race is a bad influence
Out of interest, what is your rear valence made of?
Actually may keep the steel a panels thinking about it.
Which one *wink*
dischub
Member #: 8143
London
Keep the steel a panels, ABS Motorsport is really good for service and fit. Don't whatever you do ever ever go for a one piece, the one on my mini is doing me tits in.
Placcy is the future!!
2 piece all the way rahul *smiley*
A one piece is fine, but you would need to hinge it from the bulkhead/inner wing area to make it practical
One piece are a pain the rectal area!!
dischub
Member #: 8143
London
Mines a complete removable one piece, a complete pain!!
george91
Member #: 8932
i always use the arc angels, good quality and fit, top customer service too.
tomf
Member #: 1746
Kent
I duno if iv just had bad luck but im on my third and final front end now all from different suppliers. I managed to make all of them fit pretty well for a plastic front, but the problem iv had with all of them is the gel coat has lifted away from the matting and crazed.
This has happened on all three fronts now, i dont know if i was just really unlucky with them, or if there all crap?
They all seem ok for about 6 months then the crazing starts, the first front i ground it right off back to the matting, and filled back to shape, but the others i just ground back and ended up cutting them up.
The same thing happened to two of my fibgerglass bootlids.
The only pannel it hasnt happened to is my fiberglass rear vallance.
Ill defo not be buying anymore fiberglass pannels unless i can see some evidence of some that will actually last.
Gaball
Member #: 7169
Gobshite that posts wank videos.
Somerset, UK
Arc angels I would rate well there stuff on the old college radical was perfect (y)
Gaball said:
Motorsport Engineering Student
Project Car 1293 Turbo Mini (on a student budget)
On 7th Oct, 2010 apbellamy said:
Carbon but plug?
jamz
Member #: 2292
Tool
Herne Bay, kent
im getting mine from tdk.with rmeovable bonnet. allthough it will be a removable front end ill only take it of if i really need to so it will be secured pretty well. ill get my boot from dave aswell
cant beat a good blowout.
