Home > Help Needed / General Tech Chat > actuator/ Wastegate suggestions
chominsh
Member #: 8160
, mitcham, surrey, london, cr4
HI
I have standard metro turbo engine, nothing special. Running 6psi.
my Actuator/ Wastegate is not working properly, I guess it is too old and is half way to end.
So I want to buy New one, Can any one suggest What to buy?
which ones are you running?? Originals or from other cars??
Thank you very much
Nothing special!
-31 cossie actuator should do the job nicely. Or if you have money to burn a billet one.
The -31 are uprated Cosworth, the standard actuator is good for between 10 and 15psi depending on the pre load, and can be bought for pence off ebay.
I stand corrected *happy*
chominsh
Member #: 8160
Thank you :)
However I can not fined any standard actuator for my mini on ebay :(
can anyone help me with suggesting where to buy it??
Is this one would be ok and is the price is ok??
http://cgi.ebay.co.uk/Alloy-Actuator-31-T3...=item43a1fd6bf5
Also I would love to buy standard if it will do the job, and will be cheaper than this one :)
Or should i spend bit more and buy this one??
what do you think ??
Thank you a lot!!!!!
Nothing special!
If its running 6psi, what is the problem with your actuator ?
As Tom has already said, the -31 is an uprated Cosworth actuator used by those who want higher boost than standard on a Cossie.
Standard Cossie is -16 (from memory) and it delivers 0.5-0.7bar (7-10psi) with the standard factory solenoid bleed valve (Amal valve) so I presume the standard Metro one is a lower rating still as it does 4-7psi wth the factory solenoid valve.
I suggest posting in the "wanted" section for a secondhand standard metro one.
But if your current one is "not working properly" are you sure it is the actuator and not something like a sticking wastgate ???
chominsh
Member #: 8160
Thank you for help, i will try to get standard one because i am running 7psi,
what is difference in waste-gate and actuator? is it same the same part?
my turbo unit is not working properly, sometimes it is not working at all and sometimes it shows 7psi and i can feel when it goes on :)
Also if i have standard actuator and want to put 11psi through boost controller will it work properly or will it damage it?
So probably better to buy -31 and if i will decade to run more psi it will work properly and safe??
Thank you for help :) :)
Nothing special!
the actuator controls the wastegate
it wont damage it, because it will still see the same 7psi, the boost controller would 'trick' the actuator into thinking the 11psi at the manifold is still only 7psi.... in basic terms
chominsh
Member #: 8160
Thank you!!
you helped me a lot :) :)
Nothing special!
chominsh
Member #: 8160
sorry guys i will sound stupid, however
can you show me where wastegate is located?? can you take few pic??
Also where I can buy new, and is it easy to change it??
Thank you a lot!!!
Nothing special!
Thank you a lot!!!
Really, if you're asking those questions it would be better getting someone to do it for you.
The w/g actuator is a total pain in the ass to get access too for starters.
You can't really change the wastegate as it forms part of the turbo on the T3.
chominsh
Member #: 8160
yep I thought so, Do you know any garage near London or in london how might do that for me??
or it is cheaper to buy new turbo unit?? *happy*
Nothing special!
I think you need to take the car to someone who can diagnose the problem, before even considering such rubbish as a new turbocharger.
chominsh
Member #: 8160
Yep Planing to go to Croydonminis.co.uk for servicing!
ANY feedback about them????
Nothing special!
