| Home > Help Needed / General Tech Chat > Looking for Metro turbo engine breakdown of components | |||||||
![]() 296 Posts Member #: 9117 Senior Member Northampton |
14th Nov, 2010 at 07:46:23pm
Hi all hope you can help ive searched but cant find much info im looking for info on the metro tubro engine breakdown including images for all components and correct plumbing of each,
Confessed addiction to everything mini |
![]() 1105 Posts Member #: 1504 Post Whore Westbury, Wiltshire |
14th Nov, 2010 at 08:05:19pm
You need to do some better searching matey as it's all available on here.
432 Posts Member #: 7856 Senior Member Essex |
14th Nov, 2010 at 08:12:21pm
As already said, have a search and you'll see a thread by Tom Fenton (I think) which outlines the metro turbo myths, lots of information on there, if you need pictures then you can be more specific :)
Edited by Amp on 14th Nov, 2010. |
14th Nov, 2010 at 08:40:31pm
Cool thanks have been searching through lots of great info but struggling to find photographs of engine with discriptions ill keep looking tho Confessed addiction to everything mini |
14th Nov, 2010 at 08:51:48pm
What photo's are you after in particular, I may be able to sort some out? |
14th Nov, 2010 at 10:00:30pm
thanks for the replys will try and get some pis of mine up and then i can explain what im trying to figure out Confessed addiction to everything mini |
16th Nov, 2010 at 07:37:02pm
Hi all hope these photos clear up what im talking about!! :)
16th Nov, 2010 at 08:27:24pm
1 - As it goes from the heater outlet, i assume the previous owner had overheating issues, or was afraid of them, so fitted a second radiator!
17th Nov, 2010 at 03:06:04pm
Thanks amp 1, if its for engine cooling the connecting pipes wont have a great deal of flow!
17th Nov, 2010 at 03:19:32pm
It's not a stud, it's a bolt. M8 from memory, but best to check with one of the other bolts. On 11th Feb, 2015 robert said:
17th Nov, 2010 at 03:21:57pm
On 17th Nov, 2010 apbellamy said:
It's not a stud, it's a bolt. M8 from memory, but best to check with one of the other bolts. O so does it bolt into that plate from the inside? any opinions on the other questions apbellamy i know youve been turboing with you van for a long time followed your thread on tmf Confessed addiction to everything mini |
17th Nov, 2010 at 03:32:21pm
No, it bolts through the elbow into the turbo. same as the bottom 2 bolts in the elbow.
17th Nov, 2010 at 04:11:55pm
o right just that the other two are studs! hence my assumption that the third would follow suit, thanks for the info tho!
17th Nov, 2010 at 05:15:44pm
No there are some studs holding the end plate of the turbo on. The snapped bolt and the other two that hold the elbow on are bolts. you can see that in your pic's. On 11th Feb, 2015 robert said:
17th Nov, 2010 at 05:22:08pm
People often replace the proper bolts with studs/nuts.... and usually use the wrong grade of steel hence why it sheared off.
17th Nov, 2010 at 05:37:51pm
thanks for the advice Rod going to go in with a 3mm to start it off then hopfully get some easyouts on her fingers crossed she comes out alright!
18th Nov, 2010 at 04:55:57am
For referecnce should anyone be searching the same, i have found that Ripspeed setup used to use an extra radiator in rallycross due to the low speeds requireing all the cooling possible, although the size of the connecting pipes weremuch larger than the onces used in the photo in above posts.
388 Posts Member #: 442 Senior Member Manchester |
18th Nov, 2010 at 07:33:26am
Looks like a water heated manifold that the ends have rusted up on so the've been cut off. Only other thing i can see is what looks like an air line connector sticking out the top. |
question 1 is what would be the reason for the rad on the left hand side with blue pipes that looks like its replaced the heater matrix?
noticed this today too so going to have to get this out :(
3 impritty sure but would like confermation that pictured is the standard wastegate, with the addition of a bleed valve are these sufficiant or will i require an uprated one?
