Home > Help Needed / General Tech Chat > rev counter not working
matt-atude
Member #: 8913
seaford, east sussex
rev counter not working its a TIM one, its wired up correctly and it enabled on the ecu (emerald k6) if i disconnect my rev counter and connect a my volt meter to it which has a tacho bit on it displays the revs, so is my rev counter not compatible with with the ecu, was considering getting a auto gauge tacho with shift light does anyone know if these work with emerald ecu and distributless (coil pack) ignition? cheers
matt
Johnny
Member #: 6926
Accrington
i know that you need something in order for it to work, i have a standard coil type rev counter and it doesnt work with my (megajolt) ecu, it goes all over the place. maybe just best to buy one for the ecu? someone will point you in the right direction, or use the search button,that will probably help you find an answer.
