| Home > Help Needed / General Tech Chat > engine advice | |||||||
15th Nov, 2010 at 06:36:46pm
13.95 1/4 mile on a 2.95 fd. Carnt be that hard to beat! |
15th Nov, 2010 at 07:12:38pm
hi there, i doubt you could get 16cc in there, on the standard metro pistons,
15th Nov, 2010 at 07:34:02pm
thanks benross, so wat sort of pressure wil the turbo pistons take. Ive got a low comp head but im unsure of the figures until i pull it apart in a few weeks 13.95 1/4 mile on a 2.95 fd. Carnt be that hard to beat! |
15th Nov, 2010 at 07:37:19pm
Van has the above config BENROSS mentions and we've regularly been pumping 12-15psi through it and plan on putting more in there! If something is worth doing, it's worth doing half of. |
15th Nov, 2010 at 08:00:07pm
wuithout knowing your compression ratio its impossible to say what they will take, and naturally it all depends how well its all set up. turbo 16v k-series 11.9@118.9 :)
15th Nov, 2010 at 08:13:01pm
so rule of thumb more cc more psi 13.95 1/4 mile on a 2.95 fd. Carnt be that hard to beat! |
15th Nov, 2010 at 08:25:05pm
15th Nov, 2010 at 08:26:21pm
lower compression ratio - more psi.
15th Nov, 2010 at 08:31:40pm
wats the adverage head mod in cc? I think mines around 15 13.95 1/4 mile on a 2.95 fd. Carnt be that hard to beat! |
15th Nov, 2010 at 08:32:11pm
On 15th Nov, 2010 eden7842 said:
so rule of thumb more cc more psi but not necesarily, and you must remember more psi does not = more power. its all about efficeintly producing the power. turbo 16v k-series 11.9@118.9 :)
15th Nov, 2010 at 08:35:30pm
gd point i think a gd cam is in order, anyone got 1 goin cheap in my area? 13.95 1/4 mile on a 2.95 fd. Carnt be that hard to beat! |
15th Nov, 2010 at 08:36:44pm
15th Nov, 2010 at 08:56:32pm
wats the adverage head mod in cc? I think mines around 15 The standard nominal chamber volume is 21.4cc, so unless your head's been skimmed within an inch of its life, in which case it's no use for forced induction, then it'll have more than 15cc in the chambers. |
15th Nov, 2010 at 09:10:09pm
oh i got confused so mine must be around 28cc 13.95 1/4 mile on a 2.95 fd. Carnt be that hard to beat! |
15th Nov, 2010 at 09:17:50pm
oh i got confused so mine must be around 28cc It could be anything mate, best to measure it & work out your compression properly. No good just guessing .... :) |
15th Nov, 2010 at 10:59:00pm
gd point i think a gd cam is in order, anyone got 1 goin cheap in my area? I cannot read this? Are you twelve? On 13th Jul, 2012 Ben H said:
16th Nov, 2010 at 03:24:41am
Pure Vegardise |
16th Nov, 2010 at 09:45:19am
not 12, dislexic as fuck. Engine is coming apart soon so il mesure it 13.95 1/4 mile on a 2.95 fd. Carnt be that hard to beat! |
16th Nov, 2010 at 09:54:45am
Ahh the old dislexic line. Writing gd instead of good is not dislexia, it's lazy. Fastest 998 mini in the world? 13.05 1/4 mile 106mph
![]() 190 Posts Member #: 8935 Advanced Member netherlands |
16th Nov, 2010 at 01:12:18pm
why no 1.5 rockers on forced induction engines ??? |
16th Nov, 2010 at 01:19:04pm
You can use them but some cam's are recommended to be used with 1.3 ratio rockers. The Phase 2 is one such cam I believe.
16th Nov, 2010 at 04:54:41pm
i think i might give my minisport cam ago, not got much too loose 13.95 1/4 mile on a 2.95 fd. Carnt be that hard to beat! |
1050 Posts Member #: 764 Post Whore Staffordshire |
16th Nov, 2010 at 05:38:39pm
Are you reading anything people say? |
16th Nov, 2010 at 05:50:15pm
The minisport CA2 is apparently similar to an MG metro cam. On 28th Aug, 2011 Kean said:
16th Nov, 2010 at 06:05:55pm
im just trying to keep costs down, so unless i come across a cheap cam i dont realy want to buy one.
