Home > Help Needed / General Tech Chat > locating TDC
smudger483
Member #: 8630
im having massive dramas locating TDC ive undone the timing cover and i cabt see any markings at all. ive got the car in fourth and im rocking so i see the full rotation and still nothing please help
Can you not use the marks on the pulley? I am assuming you are trying to do it at the flywheel end?
smudger483
Member #: 8630
not yet im trying to get my dizzy off. or can you just pull the dizzy off at any timing then find TDC at the pully so i can mount my trigger wheel and sensor
I haven't a bloody clue what you are trying to do. Start from the beginning and explain what you are trying to achieve so we can help.
The dizzy can be removed at any point. Don't forget to also remove the dizzy drive at the same time.
If you are fitting megajolt, you can leave the dizzy fitted, but just disconnect all the leads.
EDIT: disconnect the coil too...
Edited by apbellamy on 18th Nov, 2010.
smudger483
Member #: 8630
thanks and sorry for the confusion. im trying to take my standard dizzy off and plug it up so i can install my MJLJ. i want to install the trigger wheel with the engine still in place, thats why i was looking for TDC at the flywheel because i thought trying to find it at the pulley would be hard to fit the VR sensor correctly
In that case I would leave the dizzy where it is until you have the MJ fitted and working. That way if you can't get the MJ working you can put the leads back on the dizzy and off you go.
smudger483
Member #: 8630
ok but the reason for removing the dizzy is that it cuts out after 3500 RPM and i need room for my intercooler
Still better to leave it in until you get the trigger wheel installed right and MJ working right....
smudger483
Member #: 8630
ok will do so where are the timing marksd on the pulley and would i see them if i use a mirror
There is a plate with several pointers, but one big one, on the timing chain cover, bottom left looking from the radiator.
The pully has one small notch in it.
When the notch is next to the big pointer it's approx TDC.
The notch may be hard to spot.
If you have trouble finding it, take the rocker cover off and rotate the engine until both rockers on either No1 or No4 cylinder are the same amount down (one going up, one going down, but both about the same) - that is very close to TDC so you should then know where to look on the pully.
smudger483
Member #: 8630
thanks alot everyone
