Home > Technical Chat > Valve to block/piston clearance
What clearance would people generally allow between open valves and block/pistons?
I am using a 998 block that I had decked to clean up some damage, so the cut-outs for the exhaust valves (using 940 head) are not as deep as they once were.
It cleared before, but I've always just done them to a fixed depth as I know they clear. Just want to know what people would run so I can check.
cheers
You could always sit the head on with no gasket, turn the engine by hand to check it clears.
Not scientific, but no doubt a good way to ensure there is a safety margin there.
1.6mm is the limit for a HIGH reving engine wil............your safe at that, but i have built some at 0.6 and no problems todate
lovely job. My feeling is that it will be around 1mm, so should be ok.
I went off the clearances as described in my cams instructions kent 266. 1.5mm but I could only manage a bit under that 1.44 I think.
info here
http://www.minimania.com/ArticleV.cfm?DisplayID=1766
Disk full (/tmp/#sql_c9d4b_0.MAI); waiting for someone to free some space... (errno: 28 "No space left on device")
