| Home > Help Needed / General Tech Chat > Non turbo engine wont run, but was runnig perfectly before. | |||||||
![]() 300 Posts Member #: 1746 Senior Member Kent |
20th Nov, 2010 at 05:25:58pm
Ok well i started my 998 carb mini up this moring to warm up and when i came back out it had died. So i tried to start it again, and it would hardly idle atall (Well i say that it will idle, it litterally fires for about 3 seconds then dies) Also it wouldnt rev up atall.
20th Nov, 2010 at 05:29:20pm
Might sound daft, but has it got petrol in it? On 11th Feb, 2015 robert said:
20th Nov, 2010 at 05:31:44pm
Yep its got pertrol, and it is filling the dashpot...
20th Nov, 2010 at 06:09:17pm
coil ? change this to eliminate it
20th Nov, 2010 at 06:31:03pm
The only coil i have is from a mini with electric ignition, i presume they are different? or will it work?
20th Nov, 2010 at 06:37:54pm
should be OK for a quick test fire, but I wouldn't run it for long as it will burn out. On 11th Feb, 2015 robert said:
20th Nov, 2010 at 06:42:45pm
Ok well i just quickly went out and stuck the electric ignition coil on it and that didnt even give a spark, might be a dead coil i guess...
20th Nov, 2010 at 07:12:08pm
Ok iv just been thinking about it a bit more and the mini could have been left outside for upto half hour, with the ignition on, so could this have burnt the coil out if it was on its last legs? But just enough to give a weak spark maybe?
21st Nov, 2010 at 07:18:22pm
Ok well i stuck a new coil on it and it made no difference.
21st Nov, 2010 at 09:26:00pm
Flooded? On 26th Oct, 2004 TurboDave16v said:
21st Nov, 2010 at 09:27:36pm
as above "Turbo's make torque, and torque makes fun"
