| Home > Help Needed / General Tech Chat > Edis ground | |||||||
249 Posts Member #: 513 Senior Member Sheffield |
21st Nov, 2010 at 12:03:33am
Just wiring the Edis and megajolt up and pondering all these seperate earths I seem to have.
Forum Mod ![]() 1927 Posts Member #: 1761 Stalker Bristol |
21st Nov, 2010 at 10:38:59am
Yes, pin 7 acts as the earth for both cable shields. You don't need to earth the shielded cable at the other end. I have tried earthing the shields on both ends before and it caused huge noise issues on a mate's car.
21st Nov, 2010 at 01:28:40pm
As Carl says, do NOT ground at the other end of the shields, only at the EDIS end.
21st Nov, 2010 at 03:49:12pm
21st Nov, 2010 at 03:53:57pm
Yes pin 7 is an earth for the shields. All you need to do is splice more shielded cable on to your current pig tails, connecting the wires as you see fit and soldering the shields together.
