| Home > Help Needed / General Tech Chat > bleed valve help? | |||||||
21st Nov, 2010 at 12:51:36pm
yes, another bleed valve help thread, but before you start, ive already done a search, and ive read that there should be a pipe coming off the actuator that originally went to the ecu, and i can fit the bleed valve onto the end of this? am i correct so far?
On 15th Mar, 2012 wil_h said:
21st Nov, 2010 at 01:30:00pm
bleed valve should be in the pipe that runs from the t on the snail to the actuator. It's the signal to the actuator that needs to be bleed to fool the actuator.
21st Nov, 2010 at 01:53:22pm
Is that pipe ok to be extended slightly to save cutting the pipe in half? Put one side of the valve on the end and then another 2inch or so on the other side to the t piece on the turbo? Audi s4 b5 - 470bhp & 486ft lbs
21st Nov, 2010 at 02:28:37pm
Yes. |
21st Nov, 2010 at 02:36:17pm
Ok thanks Audi s4 b5 - 470bhp & 486ft lbs
