Home > Help Needed / General Tech Chat > megajolt connection to laptop
smudger483
Member #: 8630
ive just installed MJLJ V4 and i cant get my laptop to communicate with MJ it keeps saying "timeout reading cylinder count". i bought my USB serial converter from maplins could this be the problem
have you configured the MJ software to use the correct port?
Have a look in device manager (right click my computer, click manage, option on the left) and see what port the USB - serial adaptor has taken and configure that in the software.
Also, check the MJ unit is powered up.
smudger483
Member #: 8630
yeh done all that its using COM 5 on the laptop and thats how ive configured it on MJ
Midas
Member #: 7555
Have you downloaded a driver for the chipset in the adaptor?
smudger483
Member #: 8630
yeh the USB converter came witha disk with the driver on it and ive installed that so i think i may have to try another converter
i found it very hit and miss with the usb - serial adapters, i went through 3 before finding one that worked correctly and that cost 25 quid
I agree the USB adaptors are just aggro.
neil, you still got that old laptop you lent me?
did you get it to run your MJ?
Yup, worked a treat. Although since then the screen has died.
jamesfawcett
Member #: 218
Bingley, West Yorkshire
i bought three seriel to usb connectors, first one didnt communicate at all, second one would crash all the time, i cant remember the make of the third one i bought but it was spot on, it was someone on here that told me the make and i bought it, worked stable and perfect with that one
smudger483
Member #: 8630
thanks guys i thought it would be the converter ive just ordered one from trigger wheels so hope that one will work need to set a base map before i go on the rollers again next month by any chance has any body got one for me my specs are:
standard 998 block and gearbox
12g295 unported head
R5 T2 turbo running 6 psi
HIF 44 turbo
2" playmini exhaust
megajolt lite V4
boostjunkie
Member #: 9117
Northampton
I have exactly the same problem i have installed V4.0.2 and installed my usb parrallel reader but when i open up the software it shows in the bottom middle a message "timeout reading cylinder count" usb drivers are installed also, i have tried 2 diffrent ports on my laptop currently running windows vista, then have gone through the steps checked with multi meter the correct pins to the parralell port go into the mega jolt set correct com number (COM 10) and then applied a 9v
battery illuminating the light on the box started the program up again and still the same message
Frustraighting
It might not be the issue in this case, but a lot of software routines don't accept COM port numbers above 9 on the USB/serial converters even though you can select and display them.
Allways try to use low COM numbers with these convertors.
They are also sensitive to which USB port you plug them into (if your laptop has more than one) and will often change COM numbers when plugged into a different socket and sometimes even need the drivers re-installing when this happens. I use three eBay specials (£1.50 each) and I have them all labelled as to which socket they go in on both laptop and desktop to avoid having to re-install the drivers every time I swap things around.
smudger483
Member #: 8630
its sorted now i got a usb serial converter from trigger wheels and it works fine now
boostjunkie
Member #: 9117
Northampton
Nice to here its sorted Smudger, ive given up on the lappy and dusted off the descktop connected by parralell and worked straight away! :)
smudger483
Member #: 8630
thats what i ended up doing till i got one that worked
