| Home > Help Needed / General Tech Chat > Verto flywheel wont budge | |||||||
478 Posts Member #: 1962 Senior Member Lancaster |
22nd Nov, 2010 at 07:47:06pm
How do Gents
22nd Nov, 2010 at 08:12:57pm
Have you got the triangular bit absolutely parallel to the flywheel? You can twist the flywheel a touch if you're not careful.
22nd Nov, 2010 at 08:19:46pm
key washer
22nd Nov, 2010 at 08:36:16pm
Yep, the washer is out... And the triangular bit is parrallel |
22nd Nov, 2010 at 08:37:32pm
Ive had the same problem before. I left mine under tension over night and in the morning it was free. :)
22nd Nov, 2010 at 08:38:10pm
give it a bigger smack lol I have started posting on Instagram also my name on there is turbomk1golf
22nd Nov, 2010 at 08:50:18pm
I've taken one off before and it shoot half way across the garage! If something is worth doing, it's worth doing half of. |
88 Posts Member #: 7788 Advanced Member bradford west yorkshire |
22nd Nov, 2010 at 09:00:46pm
heat will work |
22nd Nov, 2010 at 09:52:17pm
like said, leave it under tension and leave overnight |
22nd Nov, 2010 at 10:02:36pm
you could try some very direct heat, you dont want to heat up the puller or its securring bolts , as they awill noly stretch and relieve tension,
22nd Nov, 2010 at 10:03:10pm
How do Gents
22nd Nov, 2010 at 10:04:01pm
Cheers Carl |
22nd Nov, 2010 at 11:27:59pm
ive got a 10 tonne puller, and still had to resort to the gas axe
23rd Nov, 2010 at 06:36:02am
I snapped the bolt on my old puller on a verto. tried a new one and it popped straight off On 11th Feb, 2015 robert said:
23rd Nov, 2010 at 09:02:53am
Massive tension with the puller, then Massive hammer, and massive whacks !!! ( dont forget to turn the flywheel too.
23rd Nov, 2010 at 09:37:24am
i think a 15lb hammer and a puller sorted one of mine, well it pulled the flywheel off taking come crank with it.. Yes i moved to the darkside |
25th Nov, 2010 at 03:42:58pm
The little bar steward has now budged!
25th Nov, 2010 at 05:13:13pm
was there any damage on the tail? |
25th Nov, 2010 at 05:26:04pm
If he got hit in the groin when the flywheel came of it would be more than his tail that was damaged! On 11th Feb, 2015 robert said:
27th Nov, 2010 at 06:56:20pm
Ha ha. No, no damage at all to the crank, thank god! (if there is one) |
