| Home > Help Needed / General Tech Chat > dizzy help | |||||||
88 Posts Member #: 7788 Advanced Member bradford west yorkshire |
22nd Nov, 2010 at 09:19:40pm
can i put an electronic pick up on this dizzy and do away with condensor and points i have asked before but didnt know how to put pics on http://yfrog.com/ 17dizzy002j http://yfrog.com/0edizzy007j |
23rd Nov, 2010 at 09:13:39am
You probably could, there are a few conversion kits on the market - mostly aimed at old LandRover owners, but it's essentially the same dizzy - have a search on eBay.
23rd Nov, 2010 at 12:16:54pm
If you do swap the drive dog then you should also drill up the spindle and tap so as to be able to add a small extension to mate with the drive spindle correctly otherwise it falls short and the bearings may not last as long. |
23rd Nov, 2010 at 07:30:38pm
http://img822.imageshack.us/img822/8950/mi...09engine007.jpg th |
23rd Nov, 2010 at 07:32:46pm
i am having trouble identifiying the engine as some bright spark decided to tag it up as an 850 cc however it does have a 12g940 head on and is also a carb model if this is any use to you ??? |
23rd Nov, 2010 at 08:14:30pm
Wow....
23rd Nov, 2010 at 08:51:51pm
the dizzy is held in place by 1 single bolt to the block along with a u shaped type clamp so would this be sufficient to keep it running good without changing points and condensor every 6 months ? http://cgi.ebay.co.uk/ws/eBayISAPI.dll?Vie...e=STRK:MEWAX:IT |
24th Nov, 2010 at 01:14:36pm
It's got an engine number plate. that should tell you the core engine size. 999 engines start 99... On 11th Feb, 2015 robert said:
24th Nov, 2010 at 07:00:25pm
i know how the engine codes work but like i say in my previous post sum bright spark tagged it up as an 850cc and so it begins 85 but its not 850 with 12g940 head its defo a 1275 but wasnt sure what electric pickup i could put on it as they all have requirements |
