Home > Beginners Tech > verto to pre-verto
just_jack
Member #: 2928
peterborough
Alright lads,
Time for more questions that make me look stupid,
The last few days i have been studying using the search feature now. please hold the laughter and tears i am trying my best.
When converting from verto to pre-verto what needs changing?
flywheel
friction plate
back plate
anything else you guys can add to the list,
will it require different drops, transfer casing, clutch cover, slave cylinder, clutch arm, anything like this?
All the help is appreciated
Thanks
Jack
Jack Jones
EricsAmerica
Member #: 7891
Annapolis, MD USA
You will need the obvious clutch parts that you listed (fly & plates) as well as the cover, slave, arm. Not sure if the transfer casing is the same or not...but probably at least a+ (but that shouldn't be an issue given that you are going "backwards). Drops should be the same. I'm sure others will confirm the list in case I am talking from my back side....
Eric
my pics.... http://www.fototime.com/inv/7AAF37CF3EFA956
You might need a new starter motor depending on your ring gear.
Everything else is the same other than clutch stuff including release bearing and arm.
just_jack
Member #: 2928
peterborough
Ta Eric
Oneeyedlizard, do you know if pre engaged starters are available for verto flys?
Thanks guys
Jack Jones
You'll need the appropriate keyway washer too. verto is different
t3gav
Member #: 229
Gavin@minispares.com
kent
I wrote this a while back if it helps:
Verto > Pre-Verto
PARTS IN BRACKETS INDICATE ALTERNATIVES
GHF323 SHAKEPROOF WASHER 3/8” UNF 6
GFK5240 BOLT REMOTE HOUSING SHORT 1” UNC 2
88G508 FLYWHEEL KEYWAY – PRE VERTO (EN24T) 1
2A3658 CLUTCH FLYWHEEL STRAP 6
2A3601 CLUCTH RETURN SPRING ANCHOR 1
2A3600 SLAVE CYLINDER ANCHOR TAB 1
CLZ628 CLUTCH ARM PIN – BOTTOM 1
CLZ518 CLEVIS PIN FOR CLUTCH ARM AT THE TOP 1
22A747 FLYWHEEL BOLT PRE VERTO 1
2A3657 CLUTCH BOLT LONG COVER TO PRESSURE 3
2A3659 CLUTCH FLYWHEEL STRAP BOLT SHORT 3
22A1155 FLYWHEEL BOLT LOCKTAB PRE VERTO 1
22A180MS CLUTCH PLUNGER PRE VERTO 1
1G5999 CLUTCH RETURN SPRING ON SLAVE CYLINDER 1
GRB201 CLUTCH RELEASE THRUST BEARING PRE VERTO 1
(GRB201EVO) CLUTCH RELEASE THRUST BEARING HEAVY DUTY PRE VERTO 1
22A2204MS CLUTCH LEVER ARM LONG PRE VERTO HEAVY DUTY WIDTH 1
(22A2204) CLUTCH LEVER ARM LONG PRE VERTO LATEST ORIGINAL DESIGN 1
GSY110MS CLUTCH SLAVE CYLINDER EARLY NON GENUINE 1
(GSY110) CLUTCH SLAVE CYLINDER EARLY GENUINE 1
22A598 PRESSURE PLATE DIAPHRAGM CLUTCH TYPE PRE VERTO 1
(C-AHT230) PRESSURE PLATE LIGHTENED EN8 FOR COMPETITION PRE VERTO 1
C-AHT596 CLUTCH PLATE AP RACING ROAD/RALLY PLATE 180MM 1
C-AEG481 CLUTCH DIAPHRAGM ORANGE 1
(C-AEG482) CLUTCH DIAPHRAGM GREY COMPETITION TYPE 1
(C-AEG483) CLUTCH DIAPHRAGM DOUBLE GREY RACE, FOR SINTERED PLATES 1
C-AJJ4025COMP CLUTCH HOSE BRAIDED ONE PIECE, MASTER TO SLAVE 1
C-AEG620 FLYWHEEL ULTRALIGHT FOR PRE ENGAGED STARTER IF FITTED 1
(C-AEG621) FLYWHEEL ULTRALIGHT STEEL 3.8KG FOR INERTIA STARTER 1
(C-AEG420) FLYWHEEL STEEL FOR PRE ENGAGED STARTER 1
(C-AEG421) FLYWHEEL STEEL ROAD/RALLY FOR INERTIA STARTER 1
t3gav
Member #: 229
kent
On 22nd Nov, 2010 just_jack said:
Ta Eric
Thanks guys
I think you mean pre verto flys as they would have been standard on verto, most ultralight pre verto flywheels have a choice of ringear e.g. C-AEG620
just_jack
Member #: 2928
peterborough
Thanks Gavin, well picked up on the flywheel bit aswell *blush*
Thanks guys
Jack
Jack Jones
