Home > Help Needed / General Tech Chat > Metro Turbo engine rebuild shopping list
boostjunkie
Member #: 9117
Northampton
Evening all, just compiling a shopping list for my metro turbo engine rebuild are these good choices and can i add anything?
71-4381/4 STD Vandervell Big End Bearings - 1275GT/1275 A + STD
£27.32
08-524100-00 Piston Ring Set - for 1275cc 10:1 High Compression Pistons - STD
£67.64
AEC876 Core Plug - 1275 & A plus - Cup type - 33.6mm, x 4
£7.12
A006/4 STD Glacier Thrust Washer for Cooper S/1275cc
£11.33
12A2035 Oil Filter Head Gasket - late
£0.48
C-AJJ3327 Mini Sport Lightened Vernier Duplex Timing Gear & Chain Set
£73.39
KENCF95 Kent Cam Follower Set - X-Drilled Lightweight with Oil Feed
£57.11
PIPDISC Piper Camshaft Timing Disc
£6.78
Full gasket set
£35
Centre oil pickup
CAM86614 Mini Sport Oil Pump - Slot Drive - Turbo High Capacity
£26.24
boostjunkie
Member #: 9117
Northampton
ooo
ABR-T002 Description: CAMSHAFT PHASE 2 TURBO (REPRO) £105.71
Rick.SPI
Member #: 8027
wont have high comp pistons if its a turbo, just want the standard rings for a turbo unit.
not going to get main bearing aswell as big ends?
i would either add some tools to work the head a little yourself or leave some funds to buy a modified head as this is where a fair chunk of power is released.
also i think a cross pin diff of some variety is also a wise option if your planning to drive even slightly enthusiaticly.
make sure the gaskets especially the head gaskets are exlelent quality and not the cheap options.
if u want to get stuff on time i wouldnt use minisport either lol.
Edited by Rick.SPI on 23rd Nov, 2010.
sim_ou_nao
Member #: 114
Porto/Portugal
6.78£ for this!? http://www.turbominis.co.uk/forums/attachments/268751-1.pdf
£6.78
Pedro Silva
boostjunkie
Member #: 9117
Northampton
Thanks rick for the advice :)
£27.32
H1187/3 STD Glacier Main Bearings - Cooper S/1275GT/1275cc STD
£22.62
Hepolite Slipper Piston - 1275cc - 8.8:1 Standard Compression - STD
£7.12
£11.33
£0.48
£73.39
£57.11
Full gasket set
£35
Centre oil pickup
£26.24
£105.71
Mini Sport 4 Pin Differential - Hardy Spicer Type
£137.44
hows this looking now?
EDIT: Hahahaha excellent cheers sin_ou_nao *happy*
Edited by boostjunkie on 23rd Nov, 2010.
Rick.SPI
Member #: 8027
Im not sure on the part numbers for the piston rings I'd double check when you buy them they are the right ones. And on alot of things u pay peanuts and get monkeys I would find out whether many people are using that diff and how it's going as I'm sure I've read something about it being worse than some other competitors items.
have you checked the crank to make sure it doesn't neded a re-grind before you order parts?
what about new followers?
boostjunkie
Member #: 9117
Northampton
£27.32
£22.62
£7.12
£11.33
£0.48
£73.39
£57.11
Full gasket set
£35
Centre oil pickup
£26.24
£105.71
£137.44
C-AJJ4037 Bronze Valve Guides - Competition - Set of 8
£21.82
ADU4905 Valve Stem Oil Seals, set of 8
£3.88
Rick SPI, Ill do some research on that diff whats the recommended cross pin? Thanks again :)
boostjunkie
Member #: 9117
Northampton
Rob, i have the x-drilled kent cam follower set on there, are they suitable? regarding the crank i haven't stripped the engine yet was compiling the list do you recon i should hold back on ordering the bearings untill then?
sorry bud - couldn't see the followers for looking!
I'd personally strip the engine first to see what condition its in regarding bore and crank wear before spending any money
boostjunkie
Member #: 9117
Northampton
Cool thanks for the advice rob :) not going to get round to stripping the engine till early next year unfortunatly :( desperate to start now but have no space
Are you sure that they are the turbo piston rings? I thought they were nla.
Totalseal will make you up a set of turbo compatible piston rings.
t3gav
Member #: 229
Gavin@minispares.com
kent
Why only 4 core plugs?
boostjunkie
Member #: 9117
Northampton
should be 5, how many are there on the 1275 three on front and two on engine steady side? too cold to go into garage now :(
boostjunkie
Member #: 9117
Northampton
Core Plug - 1275 & A plus - Cup type - 33.6mm, x 5?
Full gasket set
Centre oil pickup
Orange Clutch
Release bearing
Clutch oil seal
any thing ive missed? *happy*
Edited by boostjunkie on 24th Nov, 2010.
boostjunkie
Member #: 9117
Northampton
thanks jamesfawcett :)
Full gasket set
Centre oil pickup
Orange Clutch
Release bearing
Clutch oil seal
SU NEEDLE HI BOOST TURBO 10/12 PSI
Sorry, but as you haven't stripped the engine yet there are just too many unknowns.
On 24th Nov, 2010 boostjunkie said:
STD Vandervell Big End Bearings - 1275GT/1275 A + STD - don't know yet crank could need a grind.
STD Glacier Main Bearings - Cooper S/1275GT/1275cc STD - as above
Hepolite Slipper Piston - 1275cc - 8.8:1 Standard Compression - not for a turbo engine
STD Glacier Thrust Washer for Cooper S/1275cc - need to check thrust face to ensure it is ok.
Full gasket set
Centre oil pickup
Mini Sport 4 Pin Differential - Have a search for peoples opinions of this diff.
Orange Clutch
Release bearing
Clutch oil seal
those look like standard pistons. Probably not good enough for a turbo engine
boostjunkie
Member #: 9117
Northampton
Thanks minimole and apbellamy was compilng list to get idea of cost etc, but also worried about waiting time for these parts too as ive been warned about msport, would it be worth taking the risk and then if they are incorrect send them back for refund?
Cheers guys :)
cant wait to start :)
